Kyocera 1035/1135/2535/8525 two-sided copy on ftp and smb issue
gtntxrf
Hello everybody.
Few days i try to fix this problem.
First of all a can't setup this multifunctional devices after i migrate smb from ubuntu 16.04 server to FreeNAS. After i put in address book new server address and use test button i have connection error. I don't have any problems with same credentials on kyocera 2540.
This is my [global] section of /usr/local/etc/smb4.conf:
server min protocol = SMB2
server max protocol = SMB3
encrypt passwords = yes
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
max log size = 51200
max open files = 116561
logging = file
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
getwd cache = yes
guest account = nobody
map to guest = Bad User
obey pam restrictions = yes
ntlm auth = no
directory name cache size = 0
kernel change notify = no
server string = 666
ea support = yes
store dos attributes = yes
lm announce = yes
hostname lookups = yes
unix extensions = no
acl allow execute always = false
dos filemode = yes
multicast dns register = no
domain logons = no
local master = no
idmap config *: backend = tdb
server role = standalone
netbios name = BOX
workgroup = AB-S
security = user
create mask = 0666
directory mask = 0777
client ntlmv2 auth = yes
dos charset = CP437
unix charset = UTF-8
log level = 1
And this is piece of config about directory:
[SHARE01]
path = "/mnt/ada0_T2_Cry/law"
comment = Достуто только у сотрудников отдела
printable = no
veto files = /.snapshot/.windows/.mac/.zfs/
writeable = yes
browseable = yes
access based share enum = yes
recycle:repository = .recycle/%U
recycle:keeptree = yes
recycle:versions = yes
recycle:touch = yes
recycle:directory_mode = 0777
recycle:subdir_mode = 0700
vfs objects = zfs_space zfsacl streams_xattr recycle
hide dot files = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
zfsacl:acesort = dontcare
After all i try to start using ftp and i have new problem. Everything work fine but only not duplex-scan. In /var/log/messages i have this:
Sep 4 16:10:04 BOX proftpd[68895]: 127.0.0.1 (10.10.1.105[10.10.1.105]) - notice: user ftp_law: aborting transfer: Interrupted system call
First of all i want to fix smb. I can't understand how to do this
*sorry for my eng
Sounds like a crap ftp client on the printer.
It's fairly likely that your printer is trying to connect using outdated encryption, which is disabled by default on FreeNAS. If you find that you have no alternative, you can try setting the minimum protocol to SMB1.
gtntxrf
I think that too. but official answer it is
And device not have settings. I can only turn smb on or off and change port. And off course i try to switch 139 to 443. Uselessly =-(
I even try to use NTLMv1 auth in main smb settings.
gtntxrf
This is settings in web-interface
And this is settings in Kyocera Net viewer
Top Bottom
