Hello to everyone.
I have a problem that I can't solve. This is the inability to access FTP through another network.
example:
Behind dhcp server i have two network. 192.168.41.0/24 and 192.168.40.0/24 (dns and gw is 192.168.41.2)and they can communicate each to other without any limits.
My TrueNas is on address 192.168.41.9 and i setup it as ftp server which work fine except i can't access to ftp from 192.168.40.0/24 network.
log says this:Dec 7 12:51:47 freenas proftpd[2835]: 127.0.0.1 (192.168.41.2[192.168.41.2]) - SECURITY VIOLATION: Passive connection from foreign IP address 192.168.40.56 rejected (does not match client IP address 192.168.41.2).
from example - address 192.168.41.5 can access to ftp server without any problems.
for 100% we can be sure that the dhcp server is not a problem because i have small qnap nas device located on adress 192.168.41.80/24 with dns and gw 192.168.41.2 and have ftp on it and all computers from 40 network can access to his FTP .
I read that it should be added Auxiliary parameters in Truenas, and i know where to add it but i dont know what to add.
Please can anyone write what i should write in auxiliary parameters so Truenas will accept connections from second network.
thank you
example:
thank you
