I'm new to TrueNAS and my use case requires using docker containers so I went to Scale instead of Core but I have trouble setting up kubernetes.
On a fresh install, after having set up my network and created my pools and set up my shares I went to the "Apps" tab.
Here it asked me for a pool to store apps data on and then I got an error:
Complete error in spoiler:
I thought by default there would be a "local" kubernetes that starts and use my NAS as one node but it does not seem to work that way.
I found the settings for kubernetes but I do not know what to set in Cluster CIDR, Service CIDR, Cluster DNS IP (since I only want my dockers to run on my NAS).
Could you explain what I missed or point me to some documentation that could help me fix this issue?
FAILED
[EINVAL] kubernetes_update.route_v4_gateway: Please set a default route for system or for kubernetes. [EINVAL] kubernetes_update.route_v4_interface: Please set a default route for system or specify default interface to be used for kubernetes.
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 378, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 414, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1001, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/update.py", line 227, in do_update
await self.validate_data(config, 'kubernetes_update', old_config)
File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/update.py", line 158, in validate_data
verrors.check()
File "/usr/lib/python3/dist-packages/middlewared/service_exception.py", line 62, in check
raise self
middlewared.service_exception.ValidationErrors: [EINVAL] kubernetes_update.route_v4_gateway: Please set a default route for system or for kubernetes.
[EINVAL] kubernetes_update.route_v4_interface: Please set a default route for system or specify default interface to be used for kubernetes.I thought by default there would be a "local" kubernetes that starts and use my NAS as one node but it does not seem to work that way.
