kubeletes log rotation errors
browntiger
Is anyone else getting those log rotation errors in /var/log/k3s_daemon.log, related to zfs provisioning with openebs?
Dec 30 20:11:28 truenas k3s[6704]: E1230 20:11:28.780095    6704 container_log_manager.go:266] "Failed to rotate log for container" err="failed to rotate log \"/var/log/pods/kube-system_openebs-zfs-controller-0_90e6c164-8cd4-487e-8eac-a97d2aef4626/csi-provisioner/0.log\": failed to reopen container log \"87d0d98b540a0e0b9e402fb7ddd9ddaebba17ef3ec429b576f318cadae060d2d\": rpc error: code = Unknown desc = docker does not support reopening container log files" path="/var/log/pods/kube-system_openebs-zfs-controller-0_90e6c164-8cd4-487e-8eac-a97d2aef4626/csi-provisioner/0.log" containerID="87d0d98b540a0e0b9e402fb7ddd9ddaebba17ef3ec429b576f318cadae060d2d"
Dec 30 20:11:28 truenas k3s[6704]: E1230 20:11:28.781475    6704 remote_runtime.go:1168] "ReopenContainerLog from runtime service failed" err="rpc error: code = Unknown desc = docker does not support reopening container log files" containerID="59acf4428794e2ed90b8c9198b96d116351f96d55062165473112ccf693f616e"
Dec 30 20:11:28 truenas k3s[6704]: E1230 20:11:28.781560    6704 container_log_manager.go:266] "Failed to rotate log for container" err="failed to rotate log \"/var/log/pods/kube-system_openebs-zfs-controller-0_90e6c164-8cd4-487e-8eac-a97d2aef4626/snapshot-controller/0.log\": failed to reopen container log \"59acf4428794e2ed90b8c9198b96d116351f96d55062165473112ccf693f616e\": rpc error: code = Unknown desc = docker does not support reopening container log files" path="/var/log/pods/kube-system_openebs-zfs-controller-0_90e6c164-8cd4-487e-8eac-a97d2aef4626/snapshot-controller/0.log" containerID="59acf4428794e2ed90b8c9198b96d116351f96d55062165473112ccf693f616e"
Dec 30 20:11:28 truenas k3s[6704]: E1230 20:11:28.784084    6704 remote_runtime.go:1168] "ReopenContainerLog from runtime service failed" err="rpc error: code = Unknown desc = docker does not support reopening container log files" containerID="5e4e80544ba22c6f2d5573744afc283b180caabf3ebfa68010ded568f3b4e039"
Dec 30 20:11:28 truenas k3s[6704]: E1230 20:11:28.784192    6704 container_log_manager.go:266] "Failed to rotate log for container" err="failed to rotate log \"/var/log/pods/kube-system_openebs-zfs-controller-0_90e6c164-8cd4-487e-8eac-a97d2aef4626/csi-resizer/0.log\": failed to reopen container log \"5e4e80544ba22c6f2d5573744afc283b180caabf3ebfa68010ded568f3b4e039\": rpc error: code = Unknown desc = docker does not support reopening container log files" path="/var/log/pods/kube-system_openebs-zfs-controller-0_90e6c164-8cd4-487e-8eac-a97d2aef4626/csi-resizer/0.log" containerID="5e4e80544ba22c6f2d5573744afc283b180caabf3ebfa68010ded568f3b4e039"
Dec 30 20:11:28 truenas k3s[6704]: E1230 20:11:28.795296    6704 remote_runtime.go:1168] "ReopenContainerLog from runtime service failed" err="rpc error: code = Unknown desc = docker does not support reopening container log files" containerID="9bfc8f1a4448a2d3edaa9ec315d12ad75b59f7cf712ea08c55fb01e6e3625c17"
Dec 30 20:11:28 truenas k3s[6704]: E1230 20:11:28.795374    6704 container_log_manager.go:266] "Failed to rotate log for container" err="failed to rotate log \"/var/log/pods/kube-system_openebs-zfs-node-kxhcv_f4899758-5c51-44c1-8bfd-12a85f55296f/openebs-zfs-plugin/0.log\": failed to reopen container log \"9bfc8f1a4448a2d3edaa9ec315d12ad75b59f7cf712ea08c55fb01e6e3625c17\": rpc error: code = Unknown desc = docker does not support reopening container log files" path="/var/log/pods/kube-system_openebs-zfs-node-kxhcv_f4899758-5c51-44c1-8bfd-12a85f55296f/openebs-zfs-plugin/0.log" containerID="9bfc8f1a4448a2d3edaa9ec315d12ad75b59f7cf712ea08c55fb01e6e3625c17"
Dec 30 20:11:30 truenas k3s[6704]: time="2022-12-30T20:11:30-05:00" level=info msg="Using CNI configuration file /etc/cni/net.d/00-multus.conf"
Dec 30 20:11:35 truenas k3s[6704]: {"level":"warn","ts":"2022-12-30T20:11:35.274-0500","logger":"etcd-client","caller":"v3@v3.5.3-k3s1/retry_interceptor.go:62","msg":"retrying of unary invoker failed","target":"etcd-endpoints://0xc000437340/kine.sock","attempt":0,"error":"rpc error: code = Unknown desc = no such table: dbstat"}
Dec 30 20:11:35 truenas k3s[6704]: time="2022-12-30T20:11:35-05:00" level=info msg="Using CNI configuration file /etc/cni/net.d/00-multus.conf"
notanumba
Yes, i can confirm these erros:
Jan 20 20:35:00 nas k3s[12714]: time="2023-01-20T20:35:00+01:00" level=info msg="Using CNI configuration file /etc/cni/net.d/00-multus.conf"
Jan 20 20:35:00 nas k3s[12714]: E0120 20:35:00.335512 12714 container_log_manager.go:266] "Failed to rotate log for container" err="failed to rotate log \"/var/log/pods/kube-system_openebs-zfs-node-l8dmr_951822c8-edc2-42e3-9781-4fac17d75c21/openebs-zfs-plugin/0.log\": failed to rotate log \"/var/log/pods>
notanumba
Guess i found it:
Check the pool where your system is located an make sure it has free space available.
My pool was at 100% because i forgot to remove the snapshots from VM volumes i located there too, after i moved them.
System Settings \ Advanced:
After freeing space an restarting the service via shell it seems normal:
restart:
systemctl restart syslog-ng
check:
systemctl status syslog-ng.service
Did not work for me, system dataset pool has a lot of space left. Those errors coming up every 10s in the journal.
fpc
I'm getting the exact same error log, fresh installation and only turned on SMB Shares after creating a 16TB Pool...
