Kernel Panic while using Solarflare SFN5122F under load.
meanmean
Hi, I am using a FreeeNAS-11.1 U2 with an SFN5122F. When I mount a samba partition and start some large transfers I end up with a kernel panic:
panic: P2ROUNDUP(addr + 1, etp->et_enp->en_nic_cfg.enc_tx_dma_desc_boundary) >= addr + size
cpuid = 2
KDB: stack backtrace:
db_trace_self_wrapper() at db_trace_self_wrapper+0x2b/frame 0xfffffe085ceeede0
vpanic() at vpanic+0x186/frame 0xfffffe085ceeee60
panic() at panic+0x43/frame 0xfffffe085ceeeec0
siena_tx_qdesc_dma_create() at siena_tx_qdesc_dma_create+0x95/frame 0xfffffe085ceeeef0
sfxge_tx_qdpl_service() at sfxge_tx_qdpl_service+0x708/frame 0xfffffe085ceef220
sfxge_if_transmit() at sfxge_if_transmit+0x22c/frame 0xfffffe085ceef270
ether_output() at ether_output+0x6eb/frame 0xfffffe085ceef310
ip_output() at ip_output+0x1308/frame 0xfffffe085ceef440
tcp_output() at tcp_output+0x1a15/frame 0xfffffe085ceef5f0
tcp_usr_ready() at tcp_usr_ready+0x1e0/frame 0xfffffe085ceef640
sendfile_iodone() at sendfile_iodone+0xe2/frame 0xfffffe085ceef680
vn_sendfile() at vn_sendfile+0xfdb/frame 0xfffffe085ceef8e0
sendfile() at sendfile+0x145/frame 0xfffffe085ceef980
amd64_syscall() at amd64_syscall+0xa4a/frame 0xfffffe085ceefab0
Xfast_syscall() at Xfast_syscall+0xfb/frame 0xfffffe085ceefab0
--- syscall (393, FreeBSD ELF64, sys_sendfile), rip = 0x8043ec07a, rsp = 0x7fffffffe828, rbp = 0x7fffffffe900 ---
KDB: enter: panic
This doesn't seem to be related to any obvious issues such as CPU Temp etc... and I have no issue with the Realtek interface on the NAS.
Any ideas?
D
dlavigne
Guest
Well, the Realtek isn't helping as it won't be able to handle load (replace it with one of the inexpensive Intels recommended in the Hardware Recommendations PDF).
What are the hardware specs for this system?
meanmean
Thanks for the response,
The mention of the Realtek was simply to note that just accessing the system didn't cause any issues. The primary interface for file sharing is through the SFN5122F.
The NAS specs are:
i5-2400 with 32GB of DDR3
Motherboard: h67a-g43 (b3)
4x WD 2TB Greens
SFN5122F Direct Attached (Passive Copper,10GBE,MTU=9000) to a 2012 Mac Pro (SFN5122F) and a Linux Box (mellanox connectx-2).
Realtek 8111E
All connections are on separate subnets. Only, the Realtek interface has access to the internet through the LAN.
Running SMB, AFS, and a jail with plex.
Note: This seems to be an issue for other Solar Flare Cards: https://forums.freenas.org/index.php?threads/kernel-panic-on-11-1-with-sfn5162f.59443/but is fixed in FreeBSD upstream.
D
dlavigne
Guest
Did you check to see if anyone took the time to report a bug? If not, please create one and post the issue number here.
