Kernel Panic, using 12.0
ismith.hpu
Hi Free/TrueNAS community,
I am having trouble with utilizing FreeNas on the following hardware and I have attached the crash dump.
The crash happens when I attempt to connect my VEEAM server on Windows 2019 via NFS by: 10.33.102.26:/mnt/archive/nfs_archive
I have disabled zfs sync
OS/HW information:
  1. OS Version: TrueNAS-12.0-MASTER-202003240424
    1. *******Note: 11.3 crashes with a kernel panic, and so did 11.2
  2. H740P is in HBA mode with a single virtual disk with the 2x240G SSDs in RAID1.
  3. BIOS is NOT in UEFI mode.
  4. I am using the 1Gb port currently until new network hardware comes in.
My Pools are:
11x2.4TB + 1x2.4TB hot spare @ raidz2 using lz4, FreeNAS sees the bare metal drives.
Dataset:
800-BBDM : UEFI BIOS Boot Mode with GPT Partition
540-BCKU : Broadcom 57414 Dual-Port 25GbE SFP28 LOM Mezz Card
405-AAMS : PERC H740P RAID Controller, 8G B NV Cache, Mini card
400-BDSS : 240GB SSD SATA Mixed Use 6Gbps 512e 2.5in Hot-Plug S4610 Dri ve
400-AVEZ : 2.4TB 10K RPM SAS 12Gbps 512e 2.5in Hot-plug Hard Drive
384-BCJD : PowerEdge R7515 Motherboard, with 2 x 1Gb Onboard LOM (BCM57 20)
379-BDTF : 2.5 Chassis
379-BDSS : SAS/SATA Backplane
370-AEVR : 3200MT/s RDIMMs
370-AEVQ : 16GB RDIMM, 3200MT/s, Dual Ran k
338-BSWO : AMD 7302P 3GHz,16C/32T,128M,15 5W,3200
321-BERX : 2.5" Chassis with up to 24 Hot Plug Hard Drives
210-ASVQ : PowerEdge R7515 Server
  • textdump.txt
ismith.hpu
Additionally, from the iDRAC: when I rebooted and just idling clicking through the WebUI
ismith.hpu
I am there.
Do I then reboot into normal kernel and pull the log? New to FreeNAS and not sure.
ismith.hpu
There is no difference in the two files unless I pulled the debug_kernel logs incorrectly.
Is there a guide or resource you can point me towards in assisting you guys helping me?
freqlabs
This is a completely different panic. Since you're having crashes with every version of FreeNAS, maybe this is actually a hardware issue?
