So I've been with FreeNAS for about 8 months after migrating from Openfiler. The driver was to gain the use of the Zeta file system, ZFS.
For 8 months now I have tried suggestions to make the system more stable as I've recieved periodic KERNEL PANICs since the beginning.
At this point I'd say I've tried everything but hope there are some suggestions or somethingI've missed as most reciently the system crached and would not boot so I had to boot fro, mfsBSD and recover the data, then rebuild FreeNAS(For the 3rd time in 8 months)
Please tell me what I'm missing to resolve these KERNEL PANICs (We can make a 32-bit system stable corect?)
My gear:
I have a Fractel Case with power supply
NF99FL-525 motherboard with a single stick of 4G RAM
4 1.5T SEAGATE HD in ZPOOL "tank"
1 2T WDEARX HD in ZPOOL "tank2"
Running 8.3-RELEASE.img(32-bit)
Booting from SanDisk USB 2G stick
This is a 32-bit Proc/setup
I have manually tweaked the boot.loader to enable prefetch
added tunables myself as suggested by the forums
Swapped USB sticks thinking it was going bad
Enable Auto Tune (Saved, then rebooted then unchecked the option)
There is no rym of reason, it may stay up for a few days and work fine, then crash without notice. Or it may crash while streaming via MiniDLNA.
Always a KERNAL PANIC of some sort.
I can share system logs etc if you wish.
Thoughts?
My gear:
Thoughts?
