backup_truenas
- Oct 23, 2020
Like the title says, is there any way to keep Unix File Permissions when using SMB with ACL?
Use case: multiple users have access to a shared dataset from Windows / Linux using SMB, when the Linux user copies a file into the dataset, the file permissions are always set with '0755'. However, the original file permissions are '0600'.
The Windows users will only need to read the files created by the Linux users, and sometimes create new files.
It seems to me that SMB could have the capability of storing the UNIX file permissions of files created by a particular user in a form of an ACL but that doesn't seem to be the case?
Does anyone have a suggestion or a fix to keep the file permissions unmodified?
