I had been running a FreeNAS 8.3.1 box without issue for about 6 months. The other day, my router died, and as I needed to replace it, I also took the opportunity to upgrade my FreeNAS to 9.2.1.3. Once I did that, I started seeing 2 strange messages on the console I had never seen prior. Any help, or explanation would be greatly appreciated.
First message, which I know is an error:
This pops up fairly frequently, and I am not sure what is causing it. I read a bunch of old threads on the forum about this, and there seems to be a consensus that sometimes a bad SATA cable causes the issue, among other things. I will do that, but wanted to post it here beforehand, in case it is happening just because the drive is powering up and down.
Here is the output of smartctl -a /dev/ada2
The second message (totally unrelated, and if I should split this into another thread, please let me know):
This one I am pretty much baffled by, with the exception of seeing the model of my new router.
Thanks again for any help.
Apr 1 19:00:46 freenas kernel: (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 30 08 63 ca 40 99 00 00 00 00 00 Apr 1 19:00:46 freenas kernel: (ada2:ahcich2:0:0:0): CAM status: Uncorrectable parity/CRC error Apr 1 19:00:46 freenas kernel: (ada2:ahcich2:0:0:0): Retrying command
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p3 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red (AF)
Device Model: WDC WD20EFRX-68AX9N0
Serial Number: WD-WMC301585652
LU WWN Device Id: 5 0014ee 6589e6eb7
Firmware Version: 80.00A80
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Apr 2 06:25:19 2014 PDT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 242) Self-test routine in progress...
20% of test remaining.
data collection: (28020) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 283) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 181 180 021 Pre-fail Always - 3916
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 24
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 091 091 000 Old_age Always - 6858
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 23
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 18
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 5
194 Temperature_Celsius 0x0022 111 107 000 Old_age Always - 36
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 1
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Interrupted (host reset) 90% 2467 -
# 2 Extended offline Completed without error 00% 2088 -
# 3 Extended offline Interrupted (host reset) 80% 1748 -
# 4 Extended offline Interrupted (host reset) 50% 1342 -
# 5 Extended offline Completed without error 00% 1009 -
# 6 Extended offline Completed without error 00% 299 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.The second message (totally unrelated, and if I should split this into another thread, please let me know):
Apr 2 06:27:46 freenas nmbd[2685]: [2014/04/02 06:27:46.175246, 0] ../source3/nmbd/nmbd_workgroupdb.c:276(dump_workgroups) Apr 2 06:27:46 freenas nmbd[2685]: dump_workgroups() Apr 2 06:27:46 freenas nmbd[2685]: dump workgroup on subnet 192.168.2.140: netmask= 255.255.255.0: Apr 2 06:27:46 freenas nmbd[2685]: WORKGROUP(1) current master browser = RT-AC66U Apr 2 06:27:46 freenas nmbd[2685]: FREENAS 40819a23 (FreeNAS Server) Apr 2 06:27:46 freenas nmbd[2685]: RT-AC66U 400c9a03 (RT-AC66U)
