KDB: enter: panic when importing zfs
chartley21
My ixsystems freenas certified system crashed today and won't boot up. The box is only 4 months old. I haven't updated it since I got it. It gets stuck right after importing zfs. Here's the last few lines from the boot screen. Any ideas?
zfs_ioc_pool_import() at zfs_ioc_pool_import+0x163/frame 0xfffffe2020ba8740
zfsdev_ioctl() at zfs_ioc_pool_import+0x6ce/frame 0xfffffe2020ba87e0
devfs_ioctl_f() at devfs_ioctl_f+0x128/frame 0xffffe2020ba8840
kern_ioctl() at kern_ioctl+0x26d/frame 0xfffffe2020ba8840
sys_ioctl() at sys_ioctl+0x15c/frame 0xfffffe2020ba8980
amd64_syscall() at amd64_syscall+0xa38/frame 0xfffffe2020ba8ab0
fast_syscall_common() at fast_syscall_common+0x101/frame fffffe2020ba8ab0
--- syscal (54, FreeBSD ELF64, sys_ioctl), rip = 0x80120381a, rsp = 0x7fffffffb
d28, rbp = 0x7fffffffbda0 ---
KDB:enter: panic
[ thread pic 1683 tid 100944 ]
Stopped at kdb_enter+0x3b: movq $,kdb_why
chartley21
OMG. I bought two identical systems back in April/May. One is my primary on-site backup storage, the other is my off-site storage. A couple hours ago, the on-site unit crashed and won't reboot. Now the second unit has crashed! It fails to boot with the same error message. What?
Glorious1
That is scary. It sounds like you bought them from iXsystems. If so maybe you should contact them.
Okay, that is weird. What kind of workloads are we talking about? What's the pool layout?
zamana
Same here, on a consumer hardware (my backup system):
zxwut
Did anything come of this? I'm having the same issue. It just randomly started boot looping in the middle of the night.
zamana
Hi!
In my case the culprit was the boot device (a cheap pendrive). I change it for a cheap SSD (32GB only...) and never had this again until now...
skyyxy
I had same issue. During import zpool, the system will crash in 1 second, and I try to import from ubuntu zfs command but tell me the zpool zfs version is more higher and cannot import. Somebody can help please.
p33kay
This has happened to me twice now. Lost the pool had to start from begining. Had it up and running and it crashed again. Only ever happened on the 11 and 12 train
Godalo12033
Having the same issue on consumer hardware/enterprise hardware. One of my installed plugin used all available ram so the system crashed. Now when importing the pool in Truenas I get a kernel panic and the system just keeps rebooting. I pulled my pool hdds out and connect them to my pc and booted into ubuntu. When running zpool import Plex -f the system hangs and reboots. The pool does import in read only mode but I was wondering if there is any way to recover this pool.
