disconsented
- Oct 30, 2023
Hi Folks,
I've been running into the following alert, that, I believe, is preventing me from making use of K3S:
Trying to install any app results in the following:
Having a read through the journalctl logs, this is repeated ad nauseam (with ID variations):
I'm not sure if this is the same issue, or a cluster of issues. Searching around online, I've seen it commonly suggested that it's either a DNS or NTP issue. timedatectl reports what I'd expect it to, unless there is an issue with second's long lifetime on some token.
Attached are the logs for K3S from journalctl, I'm running TrueNAS-SCALE-22.12.4.2.
Any ideas on what to poke at next?
Failed to start kubernetes cluster for Applications: [EFAULT] Kube-router routes not applied as timed out waiting for pods to execute
chart.release.create Error: [EFAULT] Failed to install chart release: Error: INSTALLATION FAILED: failed pre-install: timed out waiting for the condition
Oct 30 20:34:34 truenas k3s[805789]: E1030 20:34:34.482964 805789 authentication.go:63] "Unable to authenticate the request" err="[invalid bearer token, square/go-jose: error in cryptographic primitive]" Oct 30 20:34:34 truenas k3s[805789]: 2023-10-30T20:34:34+13:00 [error] Multus: [kube-system/openebs-zfs-controller-0/]: error getting pod: Unauthorized Oct 30 20:34:34 truenas k3s[805789]: 2023-10-30T20:34:34+13:00 [error] Multus: GetPod failed: Multus: [kube-system/openebs-zfs-controller-0/]: error getting pod: Unauthorized, but continue to delete Oct 30 20:34:34 truenas k3s[805789]: 2023-10-30T20:34:34+13:00 [error] Multus: failed to get the cached delegates file: open /var/lib/cni/multus/22e0c4aae201f7b95e078515790b66938f9b4c2a387611a854ed1e25e7948860: no such file or directory, cannot properly delete
