Jails / VMs causing admin connection loss
steven6282
When starting or shutting down a jail or a VM in FreeNAS 11.2 Beta3, I'm loosing connection to the admin panel.
This wasn't happening initially when I was messing with some jails trying to get a Plex plugin to work (have another post about that, never got it to work). It seemed to start after I configured the VM to test Plex in a VM. Any time I start or stop either a VM or a Jail now, I loose connection to the admin panel.
This also seems to be causing a problem with setting up new plugins. They are not getting fully set up. If I try to install a new plex plugin now, it starts, then I loose admin connection while it says it's around 75% done. Then if I reconnect the jail is created, but not running. If I manually start it, then log in again, it is started but Plex is not running on it.
Any help with this would be greatly appreciated.
D
dlavigne
Guest
Is it due to an IP address conflict? Also, what are the hardware specs of the system and how many jails/VMs?
steven6282
No IP address conflict. The jail is having the problems when using DHCP.
Specs
Xeon 1245v6 CPU
64 GB ECC DDR4 ram
6 x 8 TB WD Red Drives RaidZ2 config
16 GB Sandisk USB OS drive
240 GB NVME drive for miscellaneous stuff that don't need data redundancy / vm ISOs, os drives, etc.
1 VM currently. 1 Jail when I try to install it.
D
dlavigne
Guest
Please create a report at bugs.freenas.org and post the issue number here.
