RedSoxNation
- Mar 18, 2017
Searched the forums/Google, but haven't found an answer.
I'm running FreeNAS-11.3-U5.
Installed calibre-web this week in a jail, using instructions I found in this forum (technically a link in this forum), and running without any issues.
I'd also like to be able to convert ebooks, so I figured it would be as simple as installing the calibre package (not just calibre-web).
However, I'm not able to find it as a package.
Tried a fresh 11.4-RELEASE-p6 jail, but still get these results:
I also tried installing using portsnap, but ran into Openssl version issues with the FreeBSD 11.x that this version of FreeNAS uses.
Am I missing something pretty simple, or is calibre no longer available?
root@test-jail:~ # pkg update The package management tool is not yet installed on your system. Do you want to fetch and install it now? [y/N]: y Bootstrapping pkg from pkg+http://pkg.FreeBSD.org/FreeBSD:11:amd64/quarterly, please wait... Verifying signature with trusted certificate pkg.freebsd.org.2013102301... done [test-jail] Installing pkg-1.15.10... [test-jail] Extracting pkg-1.15.10: 100% Updating FreeBSD repository catalogue... [test-jail] Fetching meta.conf: 100% 163 B 0.2kB/s 00:01 [test-jail] Fetching packagesite.txz: 100% 6 MiB 1.6MB/s 00:04 Processing entries: 100% FreeBSD repository update completed. 30623 packages processed. All repositories are up to date. root@test-jail:~ # pkg upgrade Updating FreeBSD repository catalogue... FreeBSD repository is up to date. All repositories are up to date. Updating database digests format: 100% Checking for upgrades (1 candidates): 100% Processing candidates (1 candidates): 100% Checking integrity... done (0 conflicting) Your packages are up to date. root@test-jail:~ # pkg install calibre Updating FreeBSD repository catalogue... FreeBSD repository is up to date. All repositories are up to date. pkg: No packages available to install matching 'calibre' have been found in the repositories
