francisaugusto
- Nov 16, 2018
And things just stopped working.
Inside the jail:
On host:
I restarted the jail, and it worked again. So annoying.
Inside the jail:
^C
root@new-nextcloud:~ # ifconfig -a
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:ff:60:7f:be:ea
hwaddr 02:a3:9b:00:0b:0b
inet6 fe80::ff:60ff:fe7f:beea%epair0b prefixlen 64 scopeid 0x2
inet 192.168.1.55 netmask 0xffffff00 broadcast 192.168.1.255
nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
status: active
groups: epair
root@new-nextcloud:~ # ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1): 56 data bytes
ping: sendto: Host is downOn host:
vnet0.6: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: new-nextcloud as nic: epair0b
options=8<VLAN_MTU>
ether 02:ff:60:7f:be:e9
hwaddr 02:e5:50:00:09:0a
inet6 fe80::ff:60ff:fe7f:bee9%vnet0.6 prefixlen 64 scopeid 0x9
status: active
group: epair
root@freenas[/mnt/NAS]# iocage get all new-nextcloud CONFIG_VERSION:26 allow_chflags:0 allow_mlock:0 allow_mount:1 allow_mount_devfs:1 allow_mount_fusefs:0 allow_mount_nullfs:0 allow_mount_procfs:0 allow_mount_tmpfs:0 allow_mount_zfs:0 allow_quotas:0 allow_raw_sockets:1 allow_set_hostname:1 allow_socket_af:1 allow_sysvipc:0 allow_tun:0 allow_vmm:0 assign_localhost:0 available:readonly basejail:0 boot:1 bpf:1 children_max:0 cloned_release:11.3-RELEASE comment:none compression:lz4 compressratio:readonly coredumpsize:off count:1 cpuset:off cputime:off datasize:off dedup:off defaultrouter:192.168.1.1 defaultrouter6:auto depends:none devfs_ruleset:8 dhcp:1 enforce_statfs:2 exec_clean:1 exec_created:/usr/bin/true exec_fib:0 exec_jail_user:root exec_poststart:/usr/bin/true exec_poststop:/usr/bin/true exec_prestart:/usr/bin/true exec_prestop:/usr/bin/true exec_start:/bin/sh /etc/rc exec_stop:/bin/sh /etc/rc.shutdown exec_system_jail_user:0 exec_system_user:root exec_timeout:60 host_domainname:med-lo host_hostname:new-nextcloud host_hostuuid:new-nextcloud host_time:1 hostid:e69c29f4-dc6f-11e8-9c3d-6c626d871dba hostid_strict_check:0 interfaces:vnet0:bridge0 ip4:new ip4_addr:vnet0|192.168.1.55/24 ip4_saddrsel:1 ip6:new ip6_addr:vnet0|accept_rtadv ip6_saddrsel:1 ip_hostname:0 jail_zfs:0 jail_zfs_dataset:iocage/jails/new-nextcloud/data jail_zfs_mountpoint:none last_started:2020-07-09 18:33:35 localhost_ip:none login_flags:-f root mac_prefix:02ff60 maxproc:off memorylocked:off memoryuse:off mount_devfs:1 mount_fdescfs:1 mount_linprocfs:0 mount_procfs:0 mountpoint:readonly msgqqueued:off msgqsize:off nat:0 nat_backend:ipfw nat_forwards:none nat_interface:none nat_prefix:172.16 nmsgq:off notes:none nsem:off nsemop:off nshm:off nthr:off openfiles:off origin:readonly owner:root pcpu:off plugin_name:none plugin_repository:none priority:99 pseudoterminals:off quota:none readbps:off readiops:off release:11.3-RELEASE-p10 reservation:none resolver:/etc/resolv.conf rlimits:off rtsold:0 securelevel:2 shmsize:off stacksize:off state:up stop_timeout:30 swapuse:off sync_state:none sync_target:none sync_tgt_zpool:none sysvmsg:new sysvsem:new sysvshm:new template:0 type:jail used:readonly vmemoryuse:off vnet:1 vnet0_mac:02ff607fbee9 02ff607fbeea vnet1_mac:none vnet2_mac:none vnet3_mac:none vnet_default_interface:auto vnet_interfaces:none wallclock:off writebps:off writeiops:off
