CONFIG_VERSION:14 allow_chflags:0 allow_mlock:0 allow_mount:0 allow_mount_devfs:0 allow_mount_nullfs:0 allow_mount_procfs:0 allow_mount_tmpfs:0 allow_mount_zfs:0 allow_quotas:0 allow_raw_sockets:0 allow_set_hostname:1 allow_socket_af:0 allow_sysvipc:0 allow_tun:0 available:readonly basejail:no boot:on bpf:no children_max:0 cloned_release:11.2-RELEASE comment:none compression:lz4 compressratio:readonly coredumpsize:off count:1 cpuset:off cputime:off datasize:off dedup:off defaultrouter:none defaultrouter6:none depends:none devfs_ruleset:4 dhcp:off enforce_statfs:2 exec_clean:1 exec_fib:0 exec_jail_user:root exec_poststart:/usr/bin/true exec_poststop:/usr/bin/true exec_prestart:/usr/bin/true exec_prestop:/usr/bin/true exec_start:/bin/sh /etc/rc exec_stop:/bin/sh /etc/rc.shutdown exec_system_jail_user:0 exec_system_user:root exec_timeout:60 host_domainname:none host_hostname:video-remux host_hostuuid:video-remux host_time:yes hostid:00000000-0000-0000-0000-0CC47A0E6A4A hostid_strict_check:off interfaces:vnet0:bridge0 ip4:new ip4_addr:none ip4_saddrsel:1 ip6:new ip6_addr:none ip6_saddrsel:1 jail_zfs:off jail_zfs_dataset:iocage/jails/video-remux/data jail_zfs_mountpoint:none last_started:2019-03-12 03:26:01 login_flags:-f root mac_prefix:02ff60 maxproc:off memorylocked:off memoryuse:off mount_devfs:1 mount_fdescfs:1 mount_linprocfs:0 mount_procfs:0 mountpoint:readonly msgqqueued:off msgqsize:off nmsgq:off notes:none nsemop:off nshm:off nthr:off openfiles:off origin:readonly owner:root pcpu:off priority:99 pseudoterminals:off quota:none release:11.2-RELEASE-p9 reservation:none resolver:/etc/resolv.conf rlimits:off securelevel:2 shmsize:off stacksize:off state:up stop_timeout:30 swapuse:off sync_state:none sync_target:none sync_tgt_zpool:none sysvmsg:new sysvsem:new sysvshm:new template:no type:jail used:readonly vmemoryuse:off vnet:off vnet0_mac:02ff60f851ca 02ff60f851cb vnet1_mac:none vnet2_mac:none vnet3_mac:none vnet_default_interface:none vnet_interfaces:none wallclock:off
vnet_default_interface:auto
U1 did but have the problems U2 has when it comes to jails.I note you're on 11.2-U1. There's a known impact for 11.2-U2. See https://www.ixsystems.com/blog/library/freenas-11-2-u2/. I'm not sure if the issue was also present in U1. It may be worthwhile retesting the jails with:
Code:vnet_default_interface:auto
If you're thinking of updating to U2.1, make sure you have a backup plan. There have been reports of data loss. For details, refer to https://www.ixsystems.com/community/threads/lost-data-in-upgrade-to-11-2.71585/
Understood. You may find that updating the jails that do require it resolves the issue anyway. No harm in trying.
iocage get all <jail>
iocage set vnet_default_interface=auto <jail>
Please provide a valid NIC to be used with vnetIf you're thinking of updating to U2.1, make sure you have a backup plan. There have been reports of data loss. For details, refer to https://www.ixsystems.com/community/threads/lost-data-in-upgrade-to-11-2.71585/
Your jails are in your pool. If your pool goes away so do your jails.Well, finally found a patter: always that a pool is detached, the jails automatically shut down. All of them. Of course, the detached pool has no relation with any jail.
Which may be due to? Any idea?
