belisarius
- Dec 4, 2013
I've seen occasional reference in the forums to the fact that lagg and jails might not work together. Based on what I've been experiencing, that's entirely possible, but I was hoping to get a more definitive "That won't work" or even better, "Here's how to make it work".
I've got two Intel 82576 integrated NIC's on the motherboard hooked up to my switch as LACP. The switch supports it, and it's configured, and works perfectly fine so long as I don't have any jails. As soon as I add jails, things start to get odd.
I've setup the jails and FreeNAS to operate on DHCP. Both the host and the jails are a 50/50 proposition to get an address - I'm running dnsmasq on an independent machine and I see the offers going out 100%, but they're just never received by FreeNAS or the jails. Now, instead of not having an address, I just don't have network connectivity on either FreeNAS or the jails. I bounce the netif service, and everything works on FreeNAS. Ditto for the jails.
So things sorta work. But every time I reboot FreeNAS (which, admittedly, won't be very often), I need to restart netif, which is a bit annoying, and probably indicates I'm not doing something right.
Here's my ifconfig output:
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=400b8<VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO>
ether 00:25:90:2a:fe:aa
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
status: active
ipfw0: flags=8800<SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0xc
lagg0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
inet 192.168.0.22 netmask 0xffffff00 broadcast 192.168.0.255
status: active
laggproto lacp lagghash l2,l3,l4
laggport: igb1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
laggport: igb0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
ether 02:77:1b:fd:3d:00
member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 17 priority 128 path cost 2000
member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 16 priority 128 path cost 2000
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 15 priority 128 path cost 2000
member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 18 priority 128 path cost 2000
member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 13 priority 128 path cost 20000
epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:f7:3a:00:12:0a
nd6 options=1<PERFORMNUD>
status: active
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:12:ba:00:0f:0a
status: active
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:84:a9:00:10:0a
status: active
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:82:01:00:11:0a
status: active
