Jails After 9.0 How Should one go about migrating everything over from the old interface/Versions?
Snow
Is there a post on how to migrated everything over from old interface Jails Ver-9 to the new jails in Ver-11? I've look and could not find any thing Clear cut about this on the forums. Also is support for the old interfaces jails stopping? I am a little confused about this and how will this all go down.
Alecmascot
There are lots.
Search for "migrate jails"
nojohnny101
@Snow This is a topic that has been discussed a lot, as @Alecmascot mentioned. Search and follow one of the many threads outlining this and if you run into problems, then you can post back with specific problems.
Snow
Thanks guys
Sorry just could not find it with the Search terms I used, did not like how I had it worded.
nojohnny101
No problem @Snow
Post back if you run into specific issues. Good luck!
