So i am still in the process of hopefully migrating my media to freenas. I'll be building a new machine for this, and i know that this new machine will be fine, but i find that i'm struggling a bit conceptually with how everything will work and i was hoping for some clarification.
This server is being built pretty much exclusively for plex transcoding, with other plugins being used on a curiosity basis. I also use it to backup files on our computers that aren't really business related but i just want to keep but thats all just a simple CIFS share.
How i understand it, is that i will need to create a volume (and a windows share) for my media itself. This will be most of my drives, i will be getting WD Red drives for this. I will also need to create a volume for the plex server plugin as well, and for this i will be using a small SSD drive as performance is really what i care about most. From that volume i will create a jail for the plex server plugin, configuring the media location as a source destination. What i'm not clear on is whether that same jail can be used for other plugins, and if not, can i create multiple jails from the same volume, or do i need a separate drive/volume for each plugin... Or do i set multiple volumes for the same SSD by not allowing it to use the whole drive...?
Obviously, not being able to play with the software and relying only on reading and youtube videos is not ideal, i just want to try and make sure i understand as much as possible so i can hit the ground running when i finally do build the new machine.
