- Jul 3, 2023
I've had this strange issue for a while. On WiFi The TrueNAS web interface and system are fully accessible, but all the jails are unreachable. On ethernet the system and jails are reachable. I don't believe this is an ap isolation issue/router problem(not completely ruled out), as wifi devices can ping the TrueNAS system itself and other devices that are also on ethernet. It's only the jails that are inaccessible.
Interestingly if I create a new jail (not reachable on WiFi) and reboot the system, for a short period of time(apoligies I don't have it exactly), that jail become reachable (can be pinged by wifi devices and can ping wifi devices). Also maybe worth noting, I can connect to Wireguard on the local network(it's NATed sharing ip with the system) and then I can connect to the jails then.
All of the jails I've configured to be accessible outside of the network are accessible outside of the network. All of the jails can ping the TrueNAS system itself, other ethernet devices, and outside of the network (ie Google), but cannot ping wifi devices.
ifconfig pre-reboot
I have an ifconfig post-reboot, but it looks identical besides the change in ids of jails, but if interested I can post.
netstat -r
cat resolve.conf
I have using the same install since FreeNAS 11, but I never had this problem with that. I believe I first noticed the problem with TrueNAS 12 and continued on in TrueNAS13.
My network is a little messy, but it works.
Modem/Router combo(required by ISP) with WiFi capabilities disabled and DHCP server disabled, set to passthrough. 192.168.1.1
Router with DHCP server which only assigned above .100 and below .250. Netmask set to /24 192.168.1.254
Simple TP-Link 10 port consumer switch
TrueNAS system 192.168.1.4
All jails are statically assigned IPs below the DHCP range. All using /24 as netmask. All using vnet and Berkeley Packet Filter, except for the Wireguard jail which uses NAT and VNET and uses /30 netmask.
Laptop 1 on ethernet 192.168.1.214 (assigned by dhcp)
Laptop 2 on wifi 192.168.1.154 (assigned by dhcp)
I've really enjoyed TrueNAS Core and the experience of learning the FreeBSD ecosystem and I'd like to keep with it! Apologies if the formatting is poor.
Thanks for any help!
ifconfig pre-reboot
igb0: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: igb0
options=4a120b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWFILTER,RXCSUM_IPV6,NOMAP>
ether ac:1f:6b:fc:ad:f6
inet 192.168.1.4 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8822<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=4e527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6,NOMAP>
ether ac:1f:6b:fc:ad:f7
status: no carrier
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
ether 58:9c:fc:10:ff:cb
member: vnet0.56 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000
member: vnet0.55 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 13 priority 128 path cost 2000
member: vnet0.45 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 2000
member: vnet0.41 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 11 priority 128 path cost 2000
member: vnet0.38 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 2000
member: vnet0.26 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 2000
member: vnet0.24 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 12 priority 128 path cost 2000
member: vnet0.18 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 14 priority 128 path cost 2000
member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
groups: bridge
vnet0.18: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: qbittorrent-public as nic: epair0b
options=8<VLAN_MTU>
ether ae:1f:6b:75:34:da
hwaddr 02:e6:16:ac:08:0a
groups: epair
status: active
vnet0.24: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: qbittorrent-media as nic: epair0b
options=8<VLAN_MTU>
ether ae:1f:6b:4c:2e:a2
hwaddr 02:4f:73:d3:b3:0a
groups: epair
status: active
vnet0.26: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: caddy as nic: epair0b
options=8<VLAN_MTU>
ether ae:1f:6b:9a:61:30
hwaddr 02:b7:87:eb:75:0a
groups: epair
status: active
vnet0.30: flags=8863<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: wireguard as nic: epair0b
options=8<VLAN_MTU>
ether ae:1f:6b:be:89:0c
hwaddr 02:c5:e9:a5:7a:0a
inet 172.16.0.1 netmask 0xfffffffc broadcast 172.16.0.3
groups: epair
status: active
vnet0.38: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: qbittorrent-books as nic: epair0b
options=8<VLAN_MTU>
ether ae:1f:6b:3b:2e:32
hwaddr 02:19:e2:8f:3d:0a
groups: epair
status: active
vnet0.41: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: qbittorrent-music as nic: epair0b
options=8<VLAN_MTU>
ether ae:1f:6b:7a:d0:cb
hwaddr 02:cb:81:bf:87:0a
groups: epair
status: active
vnet0.45: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: PlexMediaServer as nic: epair0b
options=8<VLAN_MTU>
ether ae:1f:6b:96:b1:2c
hwaddr 02:7c:27:50:46:0a
groups: epair
status: active
vnet0.55: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: audiobookshelf as nic: epair0b
options=8<VLAN_MTU>
ether ae:1f:6b:bc:1e:b5
hwaddr 02:e6:89:43:7a:0a
groups: epair
status: active
vnet0.56: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: komga as nic: epair0b
options=8<VLAN_MTU>
ether ae:1f:6b:98:cc:eb
hwaddr 02:4d:a0:85:3f:0a
groups: epair
status: active
nd6 options=9<PERFORMNUD,IFDISABLED>I have an ifconfig post-reboot, but it looks identical besides the change in ids of jails, but if interested I can post.
netstat -r
Routing tables Internet: Destination Gateway Flags Netif Expire default 192.168.1.1 UGS igb0 localhost link#3 UH lo0 172.16.0.0/30 link#5 U vnet0.30 172.16.0.1 link#5 UHS lo0 192.168.1.0/24 link#1 U igb0 192.168.1.4 link#1 UHS lo0 Internet6: Destination Gateway Flags Netif Expire ::/96 localhost UGRS lo0 localhost link#3 UHS lo0 ::ffff:0.0.0.0/96 localhost UGRS lo0 fe80::/10 localhost UGRS lo0 fe80::%lo0/64 link#3 U lo0 fe80::1%lo0 link#3 UHS lo0 ff02::/16 localhost UGRS lo0
cat resolve.conf
domain local search local nameserver 1.1.1.1 nameserver 1.0.0.1
