Moin,
somone in our IRC channel asked me if it is possible to run transmission on 8.x. Since it is not installed by default and adding php is a pain i have put it in a jail. I did this just for fun without spending too much time on securing it.
alcatraz.tar
Based on:
alcatraz.tar
Based on:
[HowTo] Setup A Jail Ontop of FreeNAS 8.x This is a Quick 'n Dirty HowTo for more information checkout - http://en.wikipedia.org/wiki/FreeBSD_jail - http://www.freebsd.org/doc/handbook/jails.html Note about my Setup: Host - teufelchen.fantaranch.tld - 192.168.1.10 - teufelchen# Jail - alcatraz.fantaranch.tld - 192.168.1.30 - alcatraz# Filesystem Layout - tank my zpool, /mnt/tank - tank/freebsd FreeBSD related files - tank/alcatraz dataset for the jail Here We Go SSH into your FreeNAS and become root. The datasets can be created on the WebUI, for demonstration i will use commandline only. teufelchen# zfs create tank/freebsd teufelchen# zfs create tank/alcatraz Download the FreeBSD Base-Files In this case via rsync from a german server. The strange commandsysntax makes sure that the correct files for your Version and Architecture are downloaded. teufelchen# cd /mnt/tank/freebsd/ teufelchen# rsync -av ftp.de.freebsd.org::FreeBSD/releases/`uname -m`/`uname -r | cut -d- -f1-2`/base/ `uname -r | cut -d- -f1-2`_`uname -m`_base receiving incremental file list created directory 8.2-RELEASE_amd64_base ./ CHECKSUM.MD5 CHECKSUM.SHA256 base.aa base.ab [...] base.mtree install.sh sent 925 bytes received 60508876 bytes 661309.30 bytes/sec total size is 60498897 speedup is 1.00 Extract the files into your new jails root directory. teufelchen# cd 8.2-RELEASE_amd64_base/ teufelchen# cat base.?? | tar --unlink -xpzf - -C /mnt/tank/alcatraz/ Now we need todo some changes to /etc/rc.conf. You can reboot at any point and the original FreeNAS freenas file will be restored. Mount / read write to allow changes teufelchen# mount -urw / Append the necessary settings to your rc.conf teufelchen# cat << ! >> /etc/rc.conf ? ### jail related settings ### ? jail_enable="YES" ? jail_list="alcatraz" ? jail_alcatraz_rootdir="/mnt/tank/alcatraz" ? jail_alcatraz_hostname="alcatraz.fantaranch.tld" ? jail_alcatraz_ip="192.168.1.30" ? jail_alcatraz_interface="alc0" ? jail_alcatraz_devfs_enable="YES" ? jail_alcatraz_mount_enable="YES" ? jail_alcatraz_fstab="/mnt/tank/freebsd/fstab.alcatraz" ? ! Create a fstab file for your jail, here you can place any filesystem to mount the fstab style. teufelchen# touch /mnt/tank/freebsd/fstab.alcatraz Set a DNS, here OpenDNS teufelchen# echo "nameserver 208.67.222.222" >> /mnt/tank/alcatraz/etc/resolv.conf And set the timezone teufelchen# cp /etc/localtime /mnt/tank/alcatraz/etc/ Now you can start your jail. teufelchen# /etc/rc.d/jail start Configuring jails:. Starting jails: alcatraz.fantaranch.tld. List running jails, the JID (JailID) is necessary to enter the jail. teufelchen# jls JID IP Address Hostname Path 14 192.168.1.30 alcatraz.fantaranch.tld /mnt/tank/alcatraz teufelchen# jexec 14 csh Now you can follow any FreeBSD/Jail related docs. alcatraz# Tip: checkout teufelchen# sysctl -a | grep jail security.jail.param.cpuset.id: 0 security.jail.param.host.hostid: 0 security.jail.param.host.hostuuid: 64 security.jail.param.host.domainname: 256 security.jail.param.host.hostname: 256 security.jail.param.children.max: 0 security.jail.param.children.cur: 0 security.jail.param.enforce_statfs: 0 security.jail.param.securelevel: 0 security.jail.param.path: 1024 security.jail.param.name: 256 security.jail.param.parent: 0 security.jail.param.jid: 0 security.jail.enforce_statfs: 2 security.jail.mount_allowed: 1 security.jail.chflags_allowed: 1 security.jail.allow_raw_sockets: 0 security.jail.sysvipc_allowed: 0 security.jail.socket_unixiproute_only: 1 security.jail.set_hostname_allowed: 1 security.jail.jail_max_af_ips: 255 security.jail.jailed: 0
