Jail Permission error with Sonarr
palmy99999
Hi All,
I have a permissions issue whereby Sonarr doesn't not have write permissions to either the dataset or perhaps there is a jail permission issue (I'm not sure which it is).
version FreeNAS-11.0-U3 (c5dcf4416)
The system was @ version 9.3 before my USB key died, after which I upgraded to Corral, imported the ZFS volume, then gave up on Corral after having issues with the Docker stopping constantly, installed version 11 and imported the ZFS volume again and started again.
I've been searching for a resolution to the following error but yet to find anything that has resolved the issue for me:
Import failed, path does not exist or is not accessible by Sonarr: /media/Entertainment/downloads/sabnzbd/complete/tv/<filename>
Permissions on my dataset appear to be correct:
Output of the command ls -l :
Sonarr, SABNZBD and CouchPotato all run under the media user and group and the UID and GID match between the Jails and FreeNAS dataset permissions.
Sonarr jail has the following storage:
Not sure what other information is useful to help troubleshoot this but please let me know if you can assist.
Thanks in advance.
SweetAndLow
Sweet'NASty
How did you mount the storage in the jail? Got a screenshot of that page?
That looks kind of odd--/mnt/DATA/Entertainment is mounted at /media/Entertainment, but /mnt/DATA/Entertainment/TV Shows is mounted at /media/TV. Is TV Shows its own dataset? If not, I'd delete that storage mountpoint entirely. If it is, it would probably make more sense to have it at /media/Entertainment/TV.
SweetAndLow
Sweet'NASty
So in your jail the path sonarr is complaining about doesn't exist. You need to make it exist and be the location you want to import your media to. /media/TV is the path in the jail not /media/Entertainment/downloads/sab
palmy99999
Thanks, it's not it's own dataset, I now recall why I added this. I was having trouble adding TV Shows to Sonarr, and after trying to add the path directly it worked, I forgot to remove it, but essentially when I had it at /mnt/DATA/Entertainment, Sonarr didn't have perms to write to the /TV Shows/ folder. I'll delete it and try again.
palmy99999
SABNZBD doesn't download to /TV Shows, that's the post-processing complete dir so I'll need to remove it I think as above. :)
palmy99999
After removing /media/TV and getting the same error, I still think there is a permissions issue. Permissions on the folder 'downloads':
Yet on the files within the newly downloaded show, the permissions are different:
palmy99999
Tried to edit above post but it wouldn't let me:
EDIT: More info from Sonarr log:
Couldn't import episode /media/Entertainment/downloads/sabnzbd/complete/tv/<New Download Folder Name> /<New file Name>: Access to the path is denied.
System.UnauthorizedAccessException: Access to the path is denied.
at System.IO.File.Move (System.String sourceFileName, System.String destFileName) [0x0013a] in /usr/wrkdirprefix/usr/ports/lang/mono/work/mono-3.10.0/mcs/class/corlib/System.IO/File.cs:319
at NzbDrone.Common.Disk.DiskProviderBase.MoveFile (System.String source, System.String destination, Boolean overwrite) [0x000e3] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Disk\DiskProviderBase.cs:222
at NzbDrone.Common.Disk.DiskTransferService.TryMoveFileVerified (System.String sourcePath, System.String targetPath, Int64 originalSize) [0x00000] in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Disk\DiskTransferService.cs:565
Lou376
I know this is an old thread but when researching this I found many similar questions but not many solutions.
I was running in to this same issue. I made sure that both the sonarr and sabnzb service accounts had access to the downloads folder as well as the final destination on the nas but I was still getting permissions errors in Sonarr.
The issue was that when sabnzb downloads a new file, it defaults the permissions to read only for the group. To fix it, I went to the Sabnzb config from the web interface and went to the folders section. You have to check the box to show advanced settings. Then I changed the "Permissions for completed downloads" to 775.
This fixed the issue for me. Hope this helps.
