I am creating a jail on FreeNas 11.1-U7. When I attempt to start the jail without any changes the jail starts, but does not get an IP. I then stop the jail and realize that it has no NIC set on it. I disable DHCP and VIMAGE in order to see the dropdown list of NIC's. It doesn't matter what NIC, I choose all of them give me the error below and the Jail fails to start. I have even attempted to put a static IP and no luck their either. How can I get the jail boot up and get an IP address either through DHCP or me assigning it statically?
ClientException('[warden_exception: ifconfig: DHCP: bad value\njail: ip4.addr: not an IPv4 address: DHCP\nERROR: Failed starting jail with above command...\n]', 22, {'class': 'warden_exception', 'frames': [{'filename': '/usr/local/lib/python3.6/site-packages/middlewared/main.py', 'lineno': 173, 'method': 'call_method', 'line': '
