I have truenas server on my local network at 192.168.0.8, and also connected to my wireguard vpn network as a client with address 10.0.0.8 (on the host freebsd, not in a jail).
I have several jails all with NAT setup with port forwarding. I can reach the truenas GUI as well as any jail services at 192.168.0.8:xyz (by specifying the port) from any machine on the 192.168.x.x subnet.
The issues is when accessing the truenas server over my vpn, I can only access the GUI (10.0.0.8:80) and shares, but other ports pointing to jails, such as 10.0.0.8:xyz that work from the local network, are not reachable from 10.0.0.0/24 machines. I have several linux servers that I access over the vpn by specifying particular ports, so the issue seems unique to truenas.
From any jail shell, I can ping all of 192.168.0.0/24, but I can only ping 10.0.0.8 on the 10.0.0.0/24 subnet. From truenas shell I can ping 192.168.0.0/24 and also all my other machines on 10.0.0.0/24.
Is there a firewall that only forwards packets to the jails, from particular subnets? How do I setup the NAT to allow jail ports access to both local network and my wireguard interface?
I could setup each jail with a connection to my vpn but would rather not do this due to extra work, certificates to manage, and extra security risk as jails are not meant to be trusted.
Thanks
Thanks
