Jail Mount Destination Stuck
EzerchE
Hello, i just installed my Freenas os to my computer.
When i try to create new jail mount point, it cannot show destination, stuck at loading forever.
garm
Hi and welcome to the forum
Sorry to hear that, hopefully the rest of your FreeNAS experience is better.
Chris Moore
http://prntscr.com/kgzzk0
Please upload your photos directly to the forum instead of external sites.
You are using the BETA version of FreeNAS, you might want to download and used the last stable release, before the BETA.
EzerchE
Hello thank you all,
Sorry for the external image i will upload it to the forum next time.
My overall experience is great, i am really happy with it. And i dont have any urgent problem. But its annoying and i wonder why it does not expand. If its a beta related general problem, its ok.
Chris Moore
It may be related to the BETA. Have you tried it in different browsers? If you can't get it to work, please file a bug report so the developers can take a look at it. There may be something that needs tweaked and the only way they know is if someone reports it.
To create an account in the ticketing system go here:
https://redmine.ixsystems.com/projects/freenas
Then actually submit the bug report from within the FreeNAS GUI. Here is the documentation:
http://doc.freenas.org/11.2/system.html#support
