FreeNas 11.2 U6 and Emby Jail Plugin
oOMrYairOo
Helo Everyone
Im running the latest freenas, I installed emby plugin and mount points but the problem is that emby dont se my movies on shared freenas folder called movies
The mount points are
The source is at /mnt/storage/movies Destination is /mnt/storage/iocage/jails/emby/root/mnt/movies
i even try /mnt/storage/iocage/jails/emby/root/media/movies
nothing at all
When i go to emby's web ui to add that folder emby dont see that movie folder
Now i opened emby's jail shell go to /mnt/movies To check UID and i have correct UID 1000 the same UID user that i access my shares over smb
How to fix this? Is this some bug in emby or what?
The same thing is hapen whit plex also i cannot see my movies folder or any other folder
I also running qbittorret whit the same mount point And everething in working fine.
But some how emby and plex dont se files on that movies folder
I even check permisions If i shell to emby jail go to /mnt/movies i can read delete create move copy files on that folder.
any ideas?
