Running FreeNAS 11.3-U3.2
I have Jackett installed as a jail (mono version 6.8.0.96). For the most part I have not encountered issues except for adding losslessclub as an indexer.
Whenever I add it, I get an error that "The SSL connection cound not be establised..."
I have tried to add this indexer on a Jackett installed on a Windows machine and it runs completely fine. Afaik, this is only an issue on my FreeNAS jail.
I checked and the OpenSSL version on the jail is 1.0.2s. Do I need to update OpenSSL to resolve this? If so, how do I do that?
Here is the error log when attempting to add losslessclub.com indexer:
{0} System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: Authentication failed, see inner exception. ---> Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED
at /usr/ports/lang/mono/work/mono-6.8.0.96/external/boringssl/ssl/handshake_client.c:1132
at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00048] in <d349126a5c244a1c9241a40862b79e0a>:0
at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000da] in <d349126a5c244a1c9241a40862b79e0a>:0
at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool)
at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <d349126a5c244a1c9241a40862b79e0a>:0
at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x000fc] in <d349126a5c244a1c9241a40862b79e0a>:0
--- End of inner exception stack trace ---
at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00262] in <d349126a5c244a1c9241a40862b79e0a>:0
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore (System.IO.Stream stream, System.Net.Security.SslClientAuthenticationOptions sslOptions, System.Threading.CancellationToken cancellationToken) [0x000c3] in <3163c3a218ad47f0abdb25d4ba342345>:0
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore (System.IO.Stream stream, System.Net.Security.SslClientAuthenticationOptions sslOptions, System.Threading.CancellationToken cancellationToken) [0x00102] in <3163c3a218ad47f0abdb25d4ba342345>:0
at System.Net.Http.HttpConnectionPool.CreateConnectionAsync (System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) [0x00322] in <3163c3a218ad47f0abdb25d4ba342345>:0
at System.Net.Http.HttpConnectionPool.WaitForCreatedConnectionAsync (System.Threading.Tasks.ValueTask`1[TResult] creationTask) [0x000a2] in <3163c3a218ad47f0abdb25d4ba342345>:0
at System.Net.Http.HttpConnectionPool.SendWithRetryAsync (System.Net.Http.HttpRequestMessage request, System.Boolean doRequestAuth, System.Threading.CancellationToken cancellationToken) [0x00089] in <3163c3a218ad47f0abdb25d4ba342345>:0
at System.Net.Http.DecompressionHandler.SendAsync (System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) [0x000ca] in <3163c3a218ad47f0abdb25d4ba342345>:0
at CloudflareSolverRe.ClearanceHandler.SendRequestAsync (System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) [0x00090] in <d04cd2ac2811440c84416674a9f38b05>:0
at CloudflareSolverRe.ClearanceHandler.SendAsync (System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) [0x000a4] in <d04cd2ac2811440c84416674a9f38b05>:0
at System.Net.Http.HttpClient.FinishSendAsyncBuffered (System.Threading.Tasks.Task`1[TResult] sendTask, System.Net.Http.HttpRequestMessage request, System.Threading.CancellationTokenSource cts, System.Boolean disposeCts) [0x0017e] in <3163c3a218ad47f0abdb25d4ba342345>:0
at Jackett.Common.Utils.Clients.HttpWebClient.Run (Jackett.Common.Utils.Clients.WebRequest webRequest) [0x0048a] in <9ed6197a044846538a1cee930676e34f>:0
at Jackett.Common.Utils.Clients.WebClient.GetString (Jackett.Common.Utils.Clients.WebRequest request) [0x0010b] in <9ed6197a044846538a1cee930676e34f>:0
at Jackett.Common.Indexers.BaseWebIndexer.RequestLoginAndFollowRedirect (System.String url, System.Collections.Generic.IEnumerable`1[T] data, System.String cookies, System.Boolean returnCookiesFromFirstCall, System.String redirectUrlOverride, System.String referer, System.Boolean accumulateCookies) [0x000cb] in <9ed6197a044846538a1cee930676e34f>:0
at Jackett.Common.Indexers.CardigannIndexer.DoLogin () [0x00165] in <9ed6197a044846538a1cee930676e34f>:0
at Jackett.Common.Indexers.CardigannIndexer.ApplyConfiguration (Newtonsoft.Json.Linq.JToken configJson) [0x00079] in <9ed6197a044846538a1cee930676e34f>:0
at Jackett.Server.Controllers.IndexerApiController.UpdateConfig (Jackett.Common.Models.DTO.ConfigItem[] config) [0x0012d] in <2b6e267ea3cf42e4906d3b7855f56988>:0
at Microsoft.AspNetCore.Mvc.Internal.ActionMethodExecutor+TaskOfIActionResultExecutor.Execute (Microsoft.AspNetCore.Mvc.Infrastructure.IActionResultTypeMapper mapper, Microsoft.Extensions.Internal.ObjectMethodExecutor executor, System.Object controller, System.Object[] arguments) [0x00071] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeActionMethodAsync () [0x00131] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeNextActionFilterAsync () [0x0009e] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.Rethrow (Microsoft.AspNetCore.Mvc.Filters.ActionExecutedContext context) [0x0001b] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.Next (Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker+State& next, Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker+Scope& scope, System.Object& state, System.Boolean& isCompleted) [0x00382] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeInnerFilterAsync () [0x0002f] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeNextResourceFilter () [0x0009f] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Rethrow (Microsoft.AspNetCore.Mvc.Filters.ResourceExecutedContext context) [0x0001b] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Next (Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker+State& next, Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker+Scope& scope, System.Object& state, System.Boolean& isCompleted) [0x00840] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeFilterPipelineAsync () [0x0002f] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeAsync () [0x0012e] in <b4ef600f4a594fe2865a8f97f915fb9d>:0
at Microsoft.AspNetCore.Builder.RouterMiddleware.Invoke (Microsoft.AspNetCore.Http.HttpContext httpContext) [0x001cb] in <6092a16d93814eba828b517a2b132f80>:0
at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke (Microsoft.AspNetCore.Http.HttpContext context) [0x00384] in <427697fe42b7459ba5302fb76d339d3b>:0
at Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware.Invoke (Microsoft.AspNetCore.Http.HttpContext context) [0x0043e] in <f352e566abf6421e87eafbcf57a0b237>:0
at Jackett.Server.Middleware.CustomExceptionHandler.Invoke (Microsoft.AspNetCore.Http.HttpContext httpContext) [0x0008a] in <2b6e267ea3cf42e4906d3b7855f56988>:0
