Version: TrueNAS-13.0-U3.1
Background: I have been running periodic snapshots on some of my datasets for a while now across 2 pools. These pools are Windows Shares (SMB). Previous Versions (PV) were working as intended.
About 2 weeks ago, I upgraded my TrueNAS server by A. migrating my TrueNAS boot drive from a spinning rust drive to a SATA SSD, and B. adding a third RAIDz1 pool also via Windows Share (SMB).
Issue: I also setup snapshots on datasets of the new pool. Upon testing Previous Versions (PV) on the new pool, they work just fine .
However, when inspecting the older 2 pools, PV only work on the subfolders of the datasets in which the path of the snapshot is set.
This is one of the datasets (Lidarr) that I have periodic snapshots. PV is empty on the root dataset folder (Lidarr) but the subfolders have them.
The issue persists on all other pools except my new one which works fine.
I've tried this on 2 different Windows 10 machines with different share credentials.
The configuration of the shares is the same for the old pools and the new one
Troubleshooting: I've tried restarting TrueNAS, restarting the SMB service, re-enabling the shares of the older pools.
Issue still persists.
Anyone have any idea how to resolve this?
