I am confronting an issue when trying to access an NFS share on TrueNAS Scale from an Zidoo Z9x media player - Z9x simply can't access the NFS share on Scale. However, settings should be correct because:
- Z9x can mount an NFS share on another NAS, a Synology
- an alternative Linux server (Ubuntu) can mount an NFS share on the TrueNAS Scale
So, neither seems to be wrongly configured.
I x-checked all relevant settings:
It's enabled, Mapall User root, Security SYS, no restrictions in network or hosts.
NFS is started and no specific settings have been made for NFS.
I also used to have TrueNAS Core, and I know that NFS access on both NAS was working, I had it set up like that. So I believe it is some kind of incompatibility between TrueNAS Scale and Z9x.
I also tried restoring the old VM, without the pool, only a single disk, which I used for a simple NFS share - and Zidoo connected at once.
I also noticed that the NFS-Share (IP-Address) does not appear on the Zidoo when I try with Scale. It does however when I try with Core. It's like Zidoo doesn't even see the share with Scale.
I restored my old TrueNAS Core VM, and tested without any pools, and confirmed that NFS was yet again working as usual. So it is definitely the Scale.
Any ways I can troubleshoot this and get Scale to work? Failing to do that, the only way will be to go back to Core, which I'm not very keen to do, there are reasons I switched. Question is also, if I can import the current ZFS pool under Scale into latest version of Core.
Thank you
Thank you
