Issues with moving my shares to freenas
xCatalystx
so long story short i've been using versions of linux for my home servers for years and have recently made the jump to freenas. I just cannot seem to get my head around the way permissions are handled as there are not providing the results I expected. Some guidance would be helpful. Im use to using the read write allow ignore lists in the samba conf. ie:
[someshare]
read list = "user1"
write list = "user2"
Than setting the appropriate file/folder masks.
I tried using the windows ACL's and they were kind of working, but than jails would be broken. If i swapped to unix than i couldn't get the windows restrictions (root level) i wanted, but jails would work fine.
An example of what i am trying to accomplish is (the previous way i did it):
[Share 1]
path = /path/to/dir
invalid users = "guest"
read list = "user1"
write list = "admin",@"administrators"
valid users = "admin",@"administrators","user1"
inherit permissions = yes
recycle bin = yes
I would than need a jail to have read/write access to a subfolder in that share; but still allow users to read/write any files the jail added/removed when mounted.
Hope this makes sense.. Spent several days trying to get this to work and about to give up and go 777 guest everything >_<
anodos
Sambassador
You want to use unix permissions and share definitions for access control. That's understandable. What is the problem you are having? Authentication (access denied to share) or permissions (share read-only or can't delete, etc)?
For reference post following:
  • Version of freenas
  • Hardware specs
  • /usr/local/etc/smb4.conf
  • Output of "getfacl <folder>" for share
xCatalystx
  • Hardware specs
anodos,
I just fixed this like 5mins ago. Taken me days... I was use to using the smb access lists (write read etc) but it wasn't working even if i edited the conf file.
Anyways after finding the getfacl / setfacl cmds i gave windows acl another shot. Seems to all be working and playing nice with my jails atm. Guess will see.
Guess the big change of freebsd + samba4 has been abit rattled. =P (been a Debian/Linux user for way to long...)
3am so i guess ill report back tomorrow if i run into any issues.
xCatalystx
So far so good. Only problem ive ran into is a mirror one.
It seems one of my jails cannot chmod files ( i believe this might be due to inheritance)
Layout is like so:
-/rootfolder (owner: full, group:full, everyone: read)
---/subfolder (owner:full, group:full, everyone: none)
Now i believe the scirpt is copying the file (to subfolder) than running chmod 664 on it.
With permissions being inherited from the subfolder , i think it is stopping it. The jail user is a member of the group inside the jail and has full rights to the files/folders in the jail (can test by ee a file that was created by another user)
Any ideas, or is what is concluded correct? Heres the output of getfacl from both inside n out.
FreeNAS-9.3-STABLE-201412090832
###FILE: INSIDE OF THE JAIL ###
# file: examplefile.log
# owner: media
# group: Administrators
user:media:rwxpDdaARWcCos:------:allow
everyone@:r-x---a-R-c---:------:allow
group@:rwxpDdaARWcCo-:------:allow
user:1002:rwxpDdaARWcCo-:------:allow //1002 is admin local to freenas, not required by jail
owner@:rwxpDdaARWcCo-:------:allow
###FILE: FREENAS ###
# owner: media
user:admin:rwxpDdaARWcCo-:------:allow
###ParentFolder: FREENAS ###
# file: Subfolder/
# owner: root
everyone@:r-x---a-R-c---:fd----:allow
group@:rwxpDdaARWcCo-:fd----:allow
user:admin:rwxpDdaARWcCo-:fd----:allow
owner@:rwxpDdaARWcCo-:fd----:allow
