Issues using pkg add
mysticpete
Hi all
Having issues using pkg add command, can anyone shed a light on this error "no manifest found"?
root@mythweb:/ # pkg add ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-8.4-release/multimedia/mythtv-0.26.0.tbzmythtv-0.26.0.tbz 100% 153MB 1.2MB/s 740.4KB/s 02:12
pkg: /tmp/mythtv-0.26.0.tbz.C41AP is not a valid package: no manifest found
It is clear that I did not request the package as detailed above so I am wondering where the mix up is?
Failed to install the following 1 package(s): ftp://ftp.freebsd.org/pub/FreeBSD/ ports/amd64/packages-8.4-release/multimedia/mythtv-0.26.0.tbz
when I look in /tmp/ I see the package but it's been renamed somehow to
mythtv-0.26.0.tbz.91yuA
D
dlavigne
Guest
The correct command would be pkg_add -r mythtv, or if on a 9.x system, pkg install mythtv. Both commands assume that a pkg is available.
mysticpete
Yes I know the commands, the package is not available under these commands hence the full path.
This does not explain the errors.
D
dlavigne
Guest
That error means that you're using a pkg_ command on a pkgng system. Use pkg install instead or build the port.
mysticpete
No, I am not using pkg_ commands
This command does not work either....
root@mythweb:/ # pkg install ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-8.4-release/multimedia/mythtv-0.26.0.tbz
Updating repository catalogue
root@mythweb:/ #
root@mythweb:/ # pkg fetch ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/package s-8.4-release/multimedia/mythtv-0.26.0.tbz
root@mythweb:/ #
Neither does pkg fetch, same response.
I do have pkgng installed
D
dlavigne
Guest
Your post is confusing--we can't tell if you're using pkg_add, pkg install, or pkg fetch, or have tried all three. If you're mixing and matching, don't, you'll muck up your pkg database.
If pkg install name_of_package isn't working, there isn't a package. Use ports instead.
mysticpete
I am not sure how you find the two commands and responses above confusing? Looks pretty straight forward to me, why not just try the commands yourself and see the result?
I have tried all 3 commands
pkg add
pkg install
pkg fetch
and none work, I even printed the responses after the command is executed...
But the old command version of pkg_add -r mythtv worked (until the package was removed from the pkg list) and pkg_add -r ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-8.4-release/multimedia/mythtv-0.26.0.tbz still works!ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-8.4-release/multimedia/mythtv-0.26.0.tbz
I am just trying to use the replacement command set and telling you it does not work in this case.
Whether you want to fix that or not is up to you guys, I'll just carry on using the old version until you remove it in a future build.
doctor15
Did you ever figure this out? I'm having the same issue with 9.2.1.5 installing mythtv
mysticpete
No the team never came back to me to update, and I know the problem is still there!
mysticpete
No, it's a plugin jail.
