lupinlicious
- Jan 13, 2020
Apps was running fine yesterday and now I see "Applications are not running", "Application(s) have failed to start: [EFAULT] Unable to configure node: Containerd socket is not available".
When I unset the pool, and choose the pool again I see
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 427, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 465, in __run_body rv = await self.method(*([self] + args)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf res = await f(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf return await func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/update.py", line 482, in do_update await self.middleware.call('kubernetes.status_change') File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1399, in call return await self._call( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1353, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/lifecycle.py", line 284, in status_change self.middleware.call_sync('kubernetes.setup_pool') File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1421, in call_sync return self.run_coroutine(methodobj(*prepared_call.args)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1461, in run_coroutine return fut.result() ^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/_base.py", line 449, in result return self.__get_result() ^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/_base.py", line 401, in __get_result raise self._exception File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/lifecycle.py", line 310, in setup_pool await self.middleware.call('kubernetes.update_server_credentials', config['dataset']) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1399, in call return await self._call( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1353, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/migrate.py", line 123, in update_server_credentials lambda d: 'cluster' in d and 'certificate-authority' in d['cluster'], kubeconfig['clusters'] ~~~~~~~~~~^^^^^^^^^^^^ TypeError: 'NoneType' object is not subscriptable
