"Failed to check for alert" after upgrade
fonze98
After upgrading to Cobia I am getting a new alert emailed to me that seems to always clear itself in less than a minute. I am looking to see if anyone else has encountered this and has come up with a solution to fix it. The alert contents can be seen below.
Failed to check for alert ScrubPaused: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/lib/python3.11/concurrent/futures/process.py", line 256, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 112, in main_worker res = MIDDLEWARE._run(*call_args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 46, in _run return self._call(name, serviceobj, methodobj, args, job=job) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 34, in _call with Client(f'ws+unix://{MIDDLEWARE_RUN_DIR}/middlewared-internal.sock', py_exceptions=True) as c: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/client/client.py", line 292, in __init__ raise ClientException('Failed connection handshake') middlewared.client.client.ClientException: Failed connection handshake """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/alert.py", line 800, in __run_source alerts = (await alert_source.check()) or [] ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/alert/source/scrub_paused.py", line 18, in check for pool in await self.middleware.call("pool.query"): ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1398, in call return await self._call( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1341, in _call return await methodobj(*prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf res = await f(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf return await func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 156, in query result = await self.middleware.call( ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1398, in call return await self._call( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1341, in _call return await methodobj(*prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf return await func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 169, in query result = await self._queryset_serialize( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 221, in _queryset_serialize return [ ^ File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 222, in await self._extend(data, extend, extend_context, extend_context_value, select) File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 235, in _extend data = await self.middleware.call(extend, data, extend_context_value) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1398, in call return await self._call( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1352, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/pool.py", line 188, in pool_extend pool |= self.middleware.call_sync('pool.pool_normalize_info', pool['name']) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1420, in call_sync return self.run_coroutine(methodobj(*prepared_call.args)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1460, in run_coroutine return fut.result() ^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/_base.py", line 449, in result return self.__get_result() ^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/_base.py", line 401, in __get_result raise self._exception File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf return await func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf res = await f(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/pool.py", line 152, in pool_normalize_info if info := await self.middleware.call('zfs.pool.query', [('name', '=', pool_name)]): ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1398, in call return await self._call( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1349, in _call return await self._call_worker(name, *prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1355, in _call_worker return await self.run_in_proc(main_worker, name, args, job) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1267, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ middlewared.client.client.ClientException: Failed connection handshake
bdubs85
I've got the same error this morning, which coincided with the scheduled scrub task I have set. I'm going to run scrub manually and see if that helps clear it up.
fonze98
Mine stopped giving the error after about 3-4 days in a row of throwing the error and my next scrub has already happened and it didn't come back hopefully all is good lol
