iSCSI ZVOL Block Size Recommendations
viniciusferrao
Hello guys,
I've read a lot of topics recommending 128k as the default block size for hosting VMs.
The question is: should this be done? This can be applied only in a particular ZVOL or should be applied in the entire pool? And finally how to this?
Thanks in advance,
viniciusferrao
Looking deeper, I've found this:
  --- Physical volume ---
  PV Name               /dev/sdb
  VG Name               VG_XenStorage-f3c604cd-325c-2664-7552-a3db49a67882
  PV Size               5.00 TB / not usable 10.00 MB
  Allocatable           yes
  PE Size (KByte)       4096
  Total PE              1310717
  Free PE               771350
  Allocated PE          539367
  PV UUID               P3AQWb-QPmm-QG4T-n16t-hyz3-rM99-3axr5p
So this is the information for iSCSI LVM on XenServer.
I think PE Size is the block size, but I'm not sure.
In my calculations 4096*1310717 results in 5.0TB, as expected.
I don't know if there any LVM experts here but it appears that the block size is 4MB.
