iSCSI service wouldn't start
hpnas
Ever since I rebooted my NAS, iSCSI wouldn't start. When I attempt to start the service from the GUI I receive the message
"The service could not be started."
I upgraded to FreeNAS-8.3.0-RELEASE-p1-x64 (r12825) but this didn't fix the issue.
Any ideas?
Too vague. What other information do you have? Hardware? What was your old version? When you say rebooted, did you reboot for any particular reason?
praecorloth
System -> Settings -> Advanced -> Show onsole messages in footer.
Reload the UI, then try starting up iSCSI and see if it gives you a more useful error message.
hpnas
Thanks for the suggestions, here is the log
Dec 23 11:29:15 freenas notifier: istgt not running? (check /var/run/istgt.pid).
Dec 23 11:29:15 freenas notifier: Starting istgt.
Dec 23 11:29:15 freenas notifier: istgt version 0.4 (20111008)
Dec 23 11:29:15 freenas istgt[5949]: istgt version 0.4 (20111008)
Dec 23 11:29:15 freenas notifier: normal mode
Dec 23 11:29:15 freenas istgt[5949]: normal mode
Dec 23 11:29:15 freenas notifier: istgt_lu_disk.c: 648:istgt_lu_disk_init: ***ERROR*** LU1: LUN0: open error
Dec 23 11:29:15 freenas istgt[5949]: istgt_lu_disk.c: 648:istgt_lu_disk_init: ***ERROR*** LU1: LUN0: open error
Dec 23 11:29:15 freenas notifier: istgt_lu.c:2058:istgt_lu_init: ***ERROR*** LU1: lu_disk_init() failed
Dec 23 11:29:15 freenas istgt[5949]: istgt_lu.c:2058:istgt_lu_init: ***ERROR*** LU1: lu_disk_init() failed
Dec 23 11:29:15 freenas notifier: istgt.c:1669:main: ***ERROR*** istgt_lu_init() failed
Dec 23 11:29:15 freenas istgt[5949]: istgt.c:1669:main: ***ERROR*** istgt_lu_init() failed
Dec 23 11:29:15 freenas notifier: LU1 HDD UNIT
Dec 23 11:29:15 freenas notifier: LU1: LUN0 file=/dev/ada2, size=2000398934016
Dec 23 11:29:15 freenas notifier: LU1: LUN0 3907029168 blocks, 512 bytes/block
Dec 23 11:29:15 freenas root: /usr/local/etc/rc.d/istgt: WARNING: failed to start istgt
Dec 23 11:29:15 freenas notifier: /usr/local/etc/rc.d/istgt: WARNING: failed to start istgt
hpnas
I found the issue, after the reboot /dev/ada2 became /dev/ada3 and that was not updated in the "Device Extents" section.
