SOLVED Could not start iSCSI service
bobthedragon
I am new to FREENAS.
I have installed FREENAS 8.03p1 on a USB drive in a HP MicroServer.
4 * HDDs + 8GB RAM
All drives are in the same ZFS pool.
I have followed the instruction to setup the iSCSI, however I could not start the service at the end. I have also rebooted the server, no luck. Has anyone experienced this?
NFS and CIFS services are enabled with no problem.
bobthedragon
Thanks for the reply.
The errors I got are:
freenas istgt[2441]: istgt_lu.c:1329:istgt_lu_add_unit: ***ERROR*** LU2: InitiatorGroup3 not found
freenas istgt[2441]: istgt_lu.c:1954:istgt_lu_init: ***ERROR*** lu_add_unit() failed
freenas istgt[2441]: istgt_lu.c:1667:main: ***ERROR*** istgt_lu_init() failed
The funny thing is I only have on initiator group setup...
bobthedragon
Another reply, I did a google search on the error and found out the cause. I have removed the initiator group ALL ALL option, service will not start without this line. It seems weird, but at least the service is started successfully.
