Hello Everyone!
I am not sure if this would be considered a cross post however my original question regarding raid 5/6 in this thread https://forums.freenas.org/index.php?threads/zfs-6-drive-raid-iscsi-storage-share-question.24074/
was answered and brought up some additional hardware related questions.
Here is my current system:
Supermicro A1SAI-2750F-O (8 Core Avoton)
16GB DDR3 1600Mhz ECC memory
6 * 3TB WD Red Drives RAIDZ2
4 * 1GB Intel NICs + dedicated IPMI
CyberPower 1000W UPS (CP1000PFCLCD)
Network equipment connected:
PFSense running on A1SRI-2558F-O with 1 WAN/ 5LAN ports
TP-Link TL-SG3216 ( 16 Port managed switch) - 3 NICs on freeNAS connected in LACP to switch on one subnet, which contains ESXi server & my office machines. 1 NIC on seperate subnet/vlan for external access i.e owncloud, ect.
The goal of this system is to be used at home as my main storage device for machine back up, extended storage, DLNA media server, FTP, owncloud, ect; the only other constant user is my wife excluding times I may share a file via FTP/owncloud. I will keep a copy of all my data on this server, but any files I consider incredibly important will be additionally backed up on a USB external & remotely. I would also like to use a portion(~1.2TB) of my storage for an iSCSI(or maybe NFS?) target for my ESXi cluster. From my basic understanding iSCSI and ZFS are not exactly the fastest solution when used together as the main volume. If this is the case what is a different budget friendly solution for iSCSI that does not use ZFS?
If it is possible to combine iSCSI/NFS for an ESXi system and use the same machine and array for general freeNAS use which of the following would you recommend for increasing performance:
1. Increase memory to 32GB (8GB X 4 1333MHZ DDR3 ECC) - I really do love these new motherboards but unfortunately mine uses SODIMM, and although the theoretical max is 64GB, I am yet to find 16GB sticks. However, the 8GB sticks are already ~$100 so I can only imagine what the 16GB would cost.
2. Add the ServeRAID M1015 controller that seems to be recommended with freeNAS.
3. One or two enterprise SSD drives (intel S3500 80GB) and use them as ZIL for the total pool. I am not sure if a mirror ZIL is needed as I have seen some discussion on the forums about this, let me know what you think.
4. Buy two (maybe four :/ ) cheaper and larger SSD drives, like the Intel 530 240GB and build out a separate array of dedicated SSD drives that will become the iSCSI target.
OR
I could scrap all of this, scale to a single ESXi node that has build in storage. :(
Thanks for looking over everything!
OR
