I'm doing some experiments in my lab with iscsi multipath.
I have a server with freenas 8.3RC1 (installed today); the server is a dell 2940 with 2 xeons, 12Gb of memory and 2 320gb sas disks.
I want to do some speed tests so I configured the disks as raid0.
A simple dd on the freenas server shows that the disk can transfer about 300MB/sec
Then I created a scsi target with 2 interfaces on different subnets (192.168.0.35/24 and 192.168.10.1/24)
On another server with proxmox vm I configured a scsi disk using multipath; the configuration seems correct and it shows both paths as active
This is my /etc/multipath.conf
I tried to measure the read speed with dd on the mounted disk and I got about 116MB/sec
If I disable one of the interfaces I get about the same speed
Here is the iperf output for the interfaces
Is it a normal behaviour ? From what I read the multipath should increase the performance using more than one connection but it does not seem to work in my case.
[root@freenas] /mnt/Raid0# ls -lh Disk00 -rw-r--r-- 1 root wheel 80G Mar 20 23:01 Disk00 [root@freenas] /mnt/Raid0# dd if=test of=/dev/null bs=32k count=524288 80000+0 records in 80000+0 records out 2621440000 bytes transferred in 8.653268 secs (302942191 bytes/sec) [root@freenas] /mnt/Raid0#
root@server:~# multipath -ll 330000000eab5e18d dm-17 FreeBSD,iSCSI Disk size=80G features='0' hwhandler='0' wp=rw `-+- policy='round-robin 0' prio=2 status=active |- 7:0:0:0 sde 8:64 active ready running `- 8:0:0:0 sdf 8:80 active ready running
blacklist { wwid * } blacklist_exceptions { wwid "330000000eab5e18d" } defaults { polling_interval 2 selector "round-robin 0" path_grouping_policy multibus getuid_callout "/lib/udev/scsi_id -g -u -d /dev/%n" rr_min_io 1000 failback immediate no_path_retry fail }
root@server:~# dd if=/dev/dm-17 of=/dev/null bs=32k count=524288 524288+0 records in 524288+0 records out 17179869184 bytes (17 GB) copied, 148.239 s, 116 MB/s
root@server:~# ifconfig eth1 down root@server:~# multipath -ll 330000000eab5e18d dm-17 FreeBSD,iSCSI Disk size=80G features='0' hwhandler='0' wp=rw `-+- policy='round-robin 0' prio=1 status=active |- 7:0:0:0 sde 8:64 failed faulty running `- 8:0:0:0 sdf 8:80 active ready running root@server:~# dd if=/dev/dm-17 of=/dev/null bs=32k count=524288 524288+0 records in 524288+0 records out 17179869184 bytes (17 GB) copied, 149.271 s, 115 MB/s root@server:~#
root@server:~# iperf -c 192.168.0.35 ------------------------------------------------------------ Client connecting to 192.168.0.35, TCP port 5001 TCP window size: 23.8 KByte (default) ------------------------------------------------------------ [ 3] local 192.168.0.252 port 55732 connected with 192.168.0.35 port 5001 [ ID] Interval Transfer Bandwidth [ 3] 0.0-10.0 sec 1.10 GBytes 941 Mbits/sec root@server:~# iperf -c 192.168.10.1 ------------------------------------------------------------ Client connecting to 192.168.10.1, TCP port 5001 TCP window size: 23.8 KByte (default) ------------------------------------------------------------ [ 3] local 192.168.10.2 port 60092 connected with 192.168.10.1 port 5001 [ ID] Interval Transfer Bandwidth [ 3] 0.0-10.0 sec 1.10 GBytes 942 Mbits/sec
