Build FreeNAS-9.10.2 (a476f16) Platform Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz
I haven't had my FreeNAS for to long, and it isn't in production yet, so I can nuke it as much as I need to get it running as needed.
Main goal is to have a Mac machine (that is connected to it via Sonnet Twin10G thunderbolt) see the Volume I created on the FreeNAS box as a local drive.
I've tried AFP, SMB and NFS, no luck with any of them.
My latest attempt is with iSCSI, setup was quick and simple, and connecting to it was easy.
Now for the headache part......
On the Mac machine, it does see the Volume as locally connected, (GREAT!) I can create, modify and delete items (more great)....except it doesn't see the data that is already on there. If (from a windows box) I go to the UNC path that I had created earlier for that Volume I can see the data just fine. On the mac machine I use the UNC, it sees all the data just fine.
ok, maybe I messed something up on the Mac machine....
Windows 2012R2 machine, i connect with iSCSI, connects nice and easy. Yet, it doesn't show any of the existing data. Doesn't even see the data the Mac put there. Heck, I even formatted it.
Any ideas?
Like I said earlier, the Primary need is to have the mac machine see it as local (the reason is so spotlight will work)
