rayearth2000
- Apr 22, 2018
I always have a lot of question, before I am using Veracrypt to create a secret driver for myself after I am using FreeNAS, someone told me to use ISCSI is much better, after setup everything is good but 2 days ago my iscsi didn't work in disk management it becomes 3 partitions , can anyone help.
512MB RAW Healthy (Primary Partition)
732 MB Healthy (Primary Partition)
2498.78 GB Healthy (Primary Partition)
here is my setting in Freenas
file in zvol
size 2.44T
Force size no check
sync: Inherit(stanfard)
compression level: Inherit
ZFS Deduplication: Inherit(off)
target Global configuration
base Name: iqn.2005-10.org.freenas.ctl
ISNS Servers:
Pool Available Space Threshold (%):
Portals
Comment: my name
Discovery Auth Method: none
Discovery Auth Group: none
portal ip: same as server address (only one network card)
Port: 3260
Initiators
Initiators: All
Authorized network: All
Targets
Target Name: data01
Target Alias: DATA001
ISCSI Group:
Portal Group ID (1 my name)
initator Group ID : 1
Auth Method : None
Authentication Group number: None
Extent Name: DATA001
Extent Type: device
Device: my zvol driver
serial :
Logical Block size 512
Available Space Threshold (%): 5
Enable TPC: box check
LUN RPM:SSD
Associated Targets
Target: data01
LuN ID :
Extent: DATA001
file in zvol
size 2.44T
Force size no check
ISNS Servers:
Portals
Comment: my name
Port: 3260
Initiators
Initiators: All
Targets
Target Name: data01
ISCSI Group:
Auth Method : None
Extent Type: device
serial :
LUN RPM:SSD
Associated Targets
Target: data01
LuN ID :
Extent: DATA001
