I have had errors showing up shortly after I upgraded from FreeNAS 11.3-U5 to TrueNAS-12.0-U5. (I plan on upgrading to TrueNAS-12.0-U6 next weekend assuming that the release goes of smoothly.) I don't know if there is a connection or if it is just coincidence.
I tried searching, but I couldn't find a readable explanation of what causes/what is happening when an IDNF error is reported. (Is this a non-existent LBA or is it something else?)
I got message about an unrecoverable error on my main pool, so I had a look at the smart parameters, and it appears that the issue had to do with the error message:
I had a recurrence of the pool error condition, and that was easily cleared, and the passed a scrub without incident.
Any insight as as to if this Is this a TrueNAS error (ZFS issue), a hardware issue (Drive DA3, the HBA, a Memory Fault-NonECC) or just corruption (System experienced a bad shutdown due to UPS failure)?
I have included a grep of the relevent messages from /var/log/messages as well as the output from smartctl below. Any insight/assistance would be much appreciated. Thanks in advance.
Log Entries Related to First incident
Log Entries Related to Second incident
Latest Smart Output:
Error: IDNF at LBA = .... The first time it happened, I was able to clear the error and I had about 100kb resilvered. I ran a badblocks (read only) on the disk as well as a full smart surface test and a zpool scrub--other than the IDNF errors there is no other indication of a problem. I had a recurrence of the pool error condition, and that was easily cleared, and the passed a scrub without incident.
Sep 24 05:31:36 freenas (da3:mps0:0:5:0): CAM status: SCSI Status Error Sep 24 05:31:36 freenas (da3:mps0:0:5:0): SCSI status: Check Condition Sep 24 05:31:36 freenas (da3:mps0:0:5:0): SCSI sense: ILLEGAL REQUEST asc:21,0 (Logical block address out of range) Sep 24 05:31:36 freenas (da3:mps0:0:5:0): Info: 0x214e59dc0 Sep 24 05:31:36 freenas (da3:mps0:0:5:0): Error 22, Unretryable error
Oct 2 14:02:00 freenas mps0: Controller reported scsi ioc terminated tgt 5 SMID 1646 loginfo 31080000 Oct 2 14:02:00 freenas mps0: (da3:mps0:0:5:0): WRITE(10). CDB: 2a 00 4f 20 6a b0 00 00 30 00 Oct 2 14:02:00 freenas Controller reported scsi ioc terminated tgt 5 SMID 909 loginfo 31080000 Oct 2 14:02:00 freenas mps0: Controller reported scsi ioc terminated tgt 5 SMID 1816 loginfo 31080000 Oct 2 14:02:00 freenas mps0: Controller reported scsi ioc terminated tgt 5 SMID 1934 loginfo 31080000 Oct 2 14:02:00 freenas mps0: (da3:mps0:0:5:0): CAM status: CCB request completed with an error Oct 2 14:02:00 freenas (da3:mps0:0:5:0): Retrying command, 3 more tries remain Oct 2 14:02:00 freenas Controller reported scsi ioc terminated tgt 5 SMID 147 loginfo 31080000 Oct 2 14:02:00 freenas mps0: Controller reported scsi ioc terminated tgt 5 SMID 812 loginfo 31080000 Oct 2 14:02:00 freenas mps0: Controller reported scsi ioc terminated tgt 5 SMID 521 loginfo 31080000 Oct 2 14:02:00 freenas mps0: Controller reported scsi ioc terminated tgt 5 SMID 2072 loginfo 31080000 Oct 2 14:02:00 freenas mps0: Controller reported scsi ioc terminated tgt 5 SMID 1786 loginfo 31080000 Oct 2 14:02:00 freenas (da3:mps0:0:5:0): WRITE(10). CDB: 2a 00 4f 20 6a 58 00 00 28 00 Oct 2 14:02:00 freenas (da3:mps0:0:5:0): CAM status: CCB request completed with an error Oct 2 14:02:00 freenas (da3:mps0:0:5:0): Retrying command, 3 more tries remain Oct 2 14:02:00 freenas (da3:mps0:0:5:0): WRITE(10). CDB: 2a 00 4f 20 6b 08 00 00 30 00 Oct 2 14:02:00 freenas (da3:mps0:0:5:0): CAM status: CCB request completed with an error Oct 2 14:02:00 freenas (da3:mps0:0:5:0): Retrying command, 3 more tries remain Oct 2 14:02:00 freenas (da3:mps0:0:5:0): WRITE(10). CDB: 2a 00 4f 20 6a e0 00 00 28 00 Oct 2 14:02:00 freenas (da3:mps0:0:5:0): CAM status: CCB request completed with an error Oct 2 14:02:00 freenas (da3:mps0:0:5:0): Retrying command, 3 more tries remain Oct 2 14:02:00 freenas (da3:mps0:0:5:0): WRITE(10). CDB: 2a 00 4f 20 6b 38 00 00 28 00 Oct 2 14:02:00 freenas (da3:mps0:0:5:0): CAM status: CCB request completed with an error Oct 2 14:02:00 freenas (da3:mps0:0:5:0): Retrying command, 3 more tries remain Oct 2 14:02:00 freenas (da3:mps0:0:5:0): WRITE(10). CDB: 2a 00 4f 20 6b 90 00 00 30 00 Oct 2 14:02:00 freenas (da3:mps0:0:5:0): CAM status: CCB request completed with an error Oct 2 14:02:00 freenas (da3:mps0:0:5:0): Retrying command, 3 more tries remain Oct 2 14:02:00 freenas (da3:mps0:0:5:0): WRITE(10). CDB: 2a 00 4f 20 6b c0 00 00 28 00 Oct 2 14:02:00 freenas (da3:mps0:0:5:0): CAM status: CCB request completed with an error Oct 2 14:02:00 freenas (da3:mps0:0:5:0): Retrying command, 3 more tries remain Oct 2 14:02:00 freenas (da3:mps0:0:5:0): WRITE(10). CDB: 2a 00 4f 20 6b 68 00 00 28 00 Oct 2 14:02:00 freenas (da3:mps0:0:5:0): CAM status: CCB request completed with an error Oct 2 14:02:00 freenas (da3:mps0:0:5:0): Retrying command, 3 more tries remain Oct 2 14:02:00 freenas (da3:mps0:0:5:0): WRITE(10). CDB: 2a 00 4f 20 6b e8 00 00 30 00 Oct 2 14:02:00 freenas (da3:mps0:0:5:0): CAM status: CCB request completed with an error Oct 2 14:02:01 freenas (da3:mps0:0:5:0): Retrying command, 3 more tries remain Oct 2 14:02:01 freenas (da3:mps0:0:5:0): WRITE(10). CDB: 2a 00 4f 20 6a 80 00 00 30 00 Oct 2 14:02:01 freenas (da3:mps0:0:5:0): CAM status: SCSI Status Error Oct 2 14:02:01 freenas (da3:mps0:0:5:0): SCSI status: Check Condition Oct 2 14:02:01 freenas (da3:mps0:0:5:0): SCSI sense: ILLEGAL REQUEST asc:21,0 (Logical block address out of range) Oct 2 14:02:01 freenas (da3:mps0:0:5:0): Info: 0x4f206a80 Oct 2 14:02:01 freenas (da3:mps0:0:5:0): Error 22, Unretryable error
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD60EFRX-68MYMN1
Serial Number: WD-REDACTED
LU WWN Device Id: 5 0014ee 20b559a84
Firmware Version: 82.00A82
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Rotation Rate: 5700 rpm
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Oct 4 16:21:41 2021 EDT
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 4784) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 702) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 221 190 021 - 7941
4 Start_Stop_Count -O--CK 100 100 000 - 472
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 031 031 000 - 50928
10 Spin_Retry_Count -O--CK 100 100 000 - 0
11 Calibration_Retry_Count -O--CK 100 100 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 113
192 Power-Off_Retract_Count -O--CK 200 200 000 - 77
193 Load_Cycle_Count -O--CK 187 187 000 - 40408
194 Temperature_Celsius -O---K 108 095 000 - 44
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb6 GPL,SL VS 1 Device vendor specific log
0xb7 GPL,SL VS 40 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 6
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 6 [5] occurred at disk power-on lifetime: 50878 hours (2119 days + 22 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
10 -- 51 00 00 00 00 4f 20 6a 80 40 00 Error: IDNF at LBA = 0x4f206a80 = 1327524480
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
61 00 30 00 00 00 00 4f 20 6a 80 40 00 7d+03:19:07.767 WRITE FPDMA QUEUED
ea 00 00 00 00 00 00 00 00 00 00 40 00 7d+03:19:06.998 FLUSH CACHE EXT
61 00 08 00 10 00 02 ba a0 f4 00 40 00 7d+03:19:06.997 WRITE FPDMA QUEUED
61 00 08 00 00 00 02 ba a0 f2 00 40 00 7d+03:19:06.997 WRITE FPDMA QUEUED
61 00 08 00 08 00 00 00 40 04 00 40 00 7d+03:19:06.997 WRITE FPDMA QUEUED
Error 5 [4] occurred at disk power-on lifetime: 50677 hours (2111 days + 13 hours)
10 -- 51 00 00 00 02 14 e5 9d c0 40 00 Error: IDNF at LBA = 0x214e59dc0 = 8940527040
61 00 08 00 00 00 02 14 e5 9d c0 40 00 41d+02:52:12.844 WRITE FPDMA QUEUED
ea 00 00 00 00 00 00 00 00 00 00 40 00 41d+02:51:52.870 FLUSH CACHE EXT
61 00 08 00 00 00 02 ba a0 f4 48 40 00 41d+02:51:52.869 WRITE FPDMA QUEUED
61 00 08 00 10 00 02 ba a0 f2 48 40 00 41d+02:51:52.869 WRITE FPDMA QUEUED
61 00 08 00 08 00 00 00 40 04 48 40 00 41d+02:51:52.869 WRITE FPDMA QUEUED
Error 4 [3] occurred at disk power-on lifetime: 45881 hours (1911 days + 17 hours)
40 -- 51 00 00 00 02 16 47 8b f0 40 00 Error: UNC at LBA = 0x216478bf0 = 8963722224
60 00 30 00 00 00 02 16 47 8b f0 40 00 3d+05:45:24.873 READ FPDMA QUEUED
60 00 28 00 00 00 02 16 47 8b 98 40 00 3d+05:45:24.832 READ FPDMA QUEUED
60 00 30 00 00 00 02 16 47 8b 68 40 00 3d+05:45:24.832 READ FPDMA QUEUED
60 00 28 00 00 00 02 16 47 8b 40 40 00 3d+05:45:24.832 READ FPDMA QUEUED
60 00 28 00 00 00 02 16 47 8b 10 40 00 3d+05:45:24.831 READ FPDMA QUEUED
Error 3 [2] occurred at disk power-on lifetime: 44438 hours (1851 days + 14 hours)
40 -- 51 00 00 00 02 5a 4c 71 00 40 00 Error: UNC at LBA = 0x25a4c7100 = 10104893696
60 00 30 00 00 00 02 5a 4c 71 00 40 00 7d+06:54:25.014 READ FPDMA QUEUED
60 00 28 00 00 00 02 5a 4c 70 a8 40 00 7d+06:54:25.014 READ FPDMA QUEUED
60 00 30 00 00 00 02 5a 4c 70 78 40 00 7d+06:54:25.013 READ FPDMA QUEUED
60 00 28 00 08 00 02 5a 4c 70 50 40 00 7d+06:54:25.013 READ FPDMA QUEUED
60 00 28 00 00 00 02 5a 4c 70 20 40 00 7d+06:54:25.013 READ FPDMA QUEUED
Error 2 [1] occurred at disk power-on lifetime: 43391 hours (1807 days + 23 hours)
40 -- 51 00 00 00 01 70 9d 21 c0 40 00 Error: UNC at LBA = 0x1709d21c0 = 6184313280
60 00 30 00 00 00 01 70 9d 21 c0 40 00 8d+04:08:24.792 READ FPDMA QUEUED
60 00 28 00 00 00 01 70 9d 21 98 40 00 8d+04:08:24.777 READ FPDMA QUEUED
60 00 28 00 00 00 01 70 9d 21 68 40 00 8d+04:08:24.777 READ FPDMA QUEUED
60 00 28 00 00 00 01 70 9d 1f 20 40 00 8d+04:08:24.776 READ FPDMA QUEUED
60 00 28 00 00 00 01 70 9d 21 10 40 00 8d+04:08:24.776 READ FPDMA QUEUED
Error 1 [0] occurred at disk power-on lifetime: 40486 hours (1686 days + 22 hours)
40 -- 51 00 00 00 02 b7 0b 30 d8 40 00 Error: UNC at LBA = 0x2b70b30d8 = 11660898520
60 00 58 00 08 00 02 b7 0b 89 f8 40 00 33d+00:38:34.307 READ FPDMA QUEUED
60 00 58 00 00 00 02 b7 0b 30 d0 40 00 33d+00:38:34.296 READ FPDMA QUEUED
60 00 58 00 08 00 02 b7 0a d7 c0 40 00 33d+00:38:34.284 READ FPDMA QUEUED
60 00 60 00 00 00 02 b7 0a 7e 88 40 00 33d+00:38:34.284 READ FPDMA QUEUED
60 00 58 00 00 00 02 b7 0a 25 48 40 00 33d+00:38:34.270 READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Extended offline Completed without error 00% 49665 -
# 2 Extended offline Completed without error 00% 49598 -
# 3 Extended offline Completed without error 00% 46102 -
# 4 Extended offline Completed without error 00% 18012 -
# 5 Extended offline Completed without error 00% 177 -
# 6 Extended offline Completed without error 00% 127 -
# 7 Extended offline Completed without error 00% 90 -
# 8 Extended offline Completed without error 00% 55 -
# 9 Extended offline Completed without error 00% 12 -
#10 Short offline Completed without error 00% 0 -
#11 Conveyance offline Completed without error 00% 0 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: Active (0)
Current Temperature: 44 Celsius
Power Cycle Min/Max Temperature: 38/47 Celsius
Lifetime Min/Max Temperature: 2/57 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (218)
Index Estimated Time Temperature Celsius
219 2021-10-04 08:24 44 *************************
... ..(476 skipped). .. *************************
218 2021-10-04 16:21 44 *************************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 1 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 4 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 797757 Vendor specific
