Is there a way to restart middlewares GUI?
KevDog
I've seen this problem now a few times which is strange since I havent encoutered it before. I'm using TrueNAS 12.0 U2. I get a message from truecommand that my freenas suddenly went offline. I can confirm the GUI is no longer reachable, however I can easily ssh into the machine and all the associated VMs and jails continue to run. Is there a way to restart the middleware GUI from the command line?
Samuel Tai
service middlewared restart
KevDog
KevDog
Hmm I've upgraded to U2 this morning and the same thing happened. The middlewared dies, I can't login via the GUI and I'm constantly getting spammed by truecommand that my system suddenly went offline. Seems I have a problem with the middlewared dying for whatever reason. Shouldn't this autorestart?
Samuel Tai
Look in /var/db/system/cores to see if your system is creating a core dump when this happens. The middleware runs on Python 3.8, so there may be a large python3.8.core file.
KevDog
It does create a python3.8.core file (or it did). I since deleted it since this was also coming up as an alert.
