SOLVED Is there a guide for setting up official MinIO app?
bboy8012
Hi All,
I thought it was self explanerotry setting up Minio in APPS, but to me it seems it's not. I don't know if I missed a step but I can get the app to start, and the new Console login page for MinIO but I can't login to it. Am I doing something idiotic and not catching it. Also the logs of the container don't show any errors on it. Thanks
error:
bboy8012
Update, so I can get it working without a certificate. So I need to figure out the certificate portion of it.
bboy8012
Figured out my issue had to do with the cert, and domain name in the container setup.
rust
Was pulling my hair out trying to get this to work with SSL (using the same Let's Encrypt wildcard from the server). I experienced the same timeout error as @bboy8012
This is my first time using truenas but I've got experience of k3s so I did a bit of a hack to get it to work.
This will need to be applied after each upgrade.
sudo k3s kubectl -n ix-minio patch deployment minio -p "{\"spec\": {\"template\": {\"spec\": {\"hostNetwork\": true}}}}"
Hopefully someone can improve on this solution.
zuntaruk
@rust, thanks for sharing! That did indeed help my installation work as well.
I went ahead and created a ticket for them to see if we can get them to take a look at just fixing the app itself :).
Fingers crossed!
edit: hit enter too early, adding rest of message.
