Is t Possible to Have Two FreeNAS on the Same Home Network
DMP
Is it Possible to Have Two FreeNAS on the Same Home Network
OK, I build a second and larger FreeNAS RaidZ1 with four 2TB WD Red drives to replace my aging older Seagate drive. When they're both plugged into the local network only one is visible in the Network section of Windows Explorer. Both are visible by their IP address. Is where a way to rename one so both will show up. Otherwise I'm stuck moving all the files to another drive and then to the new FreeNAS system. Thanks for your time. Phil
praecorloth
It's possible that both are set to be the master browser for your network, and thus neither of them would broadcast their name over NetBIOS. Go in to the CIFS settings page and make sure that Local Master is only checked on one of the FreeNAS machines. That's about the best I can come up with.
DMP
Thanks for the reply. I'll check it out this evening.
Stephens
Give them different NETBIOS names in CIFS settings.
