Is Scale Affected by Dirty Pipe Exploit?
jgreco
Resident Grinch
How would it be "already patched"?
It isn't really a problem unless you're letting users log directly onto your server and get a shell. Which is always a bad idea.
HarryMuscle
The kernel was patched last month before this exploit was made public so depending which kernel version is being used in the release version of Scale it could already be patched.
Thanks,
Harry
According to BC
While the bug has been fixed in Linux kernels 5.16.11, 5.15.25, and 5.10.102, many servers continue to run outdated kernels making the release of this exploit a significant issue to server administrators.
Current SCALE Angelfish release and Bluefin nightlies are using 5.10.93, so unless you need it, disable SSH
root@NAS-3[~]# uname -a
Linux NAS-3 5.10.93+truenas #1 SMP Wed Feb 23 14:35:55 UTC 2022 x86_64 GNU/Linux
root@NAS-3[~]#
Latest nightlies are running newer kernel.
TrueNAS-SCALE-22.12-MASTER-20220310-132924
Linux NAS-3 5.10.103+truenas #1 SMP Tue Mar 8 20:31:49 UTC 2022 x86_64 GNU/Linux
