Is Raidz1 an acceptable risk as a backup pool?
I have a primary pool running in a 12x2TB raidz2 config that has been performing well although smart shows some drives with high errors (crc failures - cable issue not the drives themselves I discovered).
I currently have approx 20TB of usable space on one server and had a 2nd one with simply multiple drives keeping straight backups of the ZFS system. I realize that is a very poor backup strategy but haven’t been sure how to proceed.
I have 5X5TB that I would like to use as a back up server that turns on once a week and copies all the new stuff from the main server before shutting down. I’m wondering if using raidz1 with the backup pool is an acceptable risk if I also have the primary pool in raidz2. If anything goes wrong with the back up pool I can fix it from the primary, therefore it’s pretty much safe to assume it will always be healthy if the primary suffers catestrophic 2 disk failure.
rs225
Very acceptable. Just remember to have testing and notifications set up on the backup too.
Waco
The only risk of RAIDZ1 is that you can lose data due to unrecoverable bit errors if you rebuild when a drive dies. It is not the death sentence that everyone exclaims it to be. Weigh the chance of a drive death or bit error happening on your backup pool when your main pool dies. In reality, you're already being more paranoid than most...you have a backup pool!
