- Nov 25, 2013
Hi all,
the mentioned setting should theoretically permit a system that is configured as an IPv6 router (like my OpenVPN gateway) to still receive its IPv6 default router via RA on the external interface. So on a regular host this configuration does what it should do:
Yet, for some reason in a jail, it doesn't. Simply replace
These should set the flag
When I configure all of this manually, like this:
then everything works as it should.
Any hints welcome.
Thanks!
Patrick
ifconfig_igb0_ipv6="inet6 accept_rtadv auto_linklocal" ipv6_gateway_enable="YES" ipv6_cpe_wanif="igb0"
igb0 with epair0b and you have my jail settings.These should set the flag
-no_radr on the mentioned interface with ifconfig and set these two sysctls to 1:Code:
net.inet6.ip6.no_radr: 0 net.inet6.ip6.rfc6204w3: 0
# rc.conf ifconfig_epair0b_ipv6="inet6 accept_rtadv -no_radr auto_linklocal" # no ipv6_gateway_enable ... # sysctl.conf net.inet6.ip6.no_radr=1 net.inet6.ip6.rfc6204w3=1 net.inet6.ip6.forwarding=1
Any hints welcome.
Thanks!
Patrick
