IPv6 and FreeNAS
George51
Sure I am being dense, and missing something stupid. And a good time to caveat I am only just getting used to IPv6 - my knowledge is extremely limited.
Trying to get IPv6 working on my network, have (I believe) set it up correctly on my pfSense box. On my other devices I can connect to and ping ipv6 only websites - for example ipv6.google.com
On FreeNAS however, I have enabled IPv6 autoconfigure on the primary interface, I see on the dashboard that it is picking up IPv6 default routes etc, however it is only showing the IPv4 address. Not a drama, maybe it doesn't display both.
However from shell when I ping ipv6.google.com it does not work I get:
ping: cannot resolve ipv6.google.com: Unknown server error
Some googling led me to believe I needed a IPv6 capable nameserver.
I've currently got
192.168.1.1 (my pfsense box)
8.8.8.8
I've tried adding a variety of what I think may be appropriate as my third: IE the pfsense link local address, or its full ipv6 address, neither seem to make a difference.
scrappy
Are you using ping6 command to ping ipv6 addresses?
scrappy
I've currently got
8.8.8.8
Those are IPv4 DNS addresses.
For Google's IPv6 DNS servers you can use the following:
  • 2001:4860:4860::8888
  • 2001:4860:4860::8844
You could also try Quad9's DNS with the following:
  • Secure IPv6 Primary: 2620:fe::fe Blocklist, DNSSEC, No EDNS Client-Subnet
  • Secure IPv6 Secondary: 2620:fe::9 Blocklist, DNSSEC, No EDNS Client-Subnet
  • Unsecured IPv6 Primary: 2620:fe::10 No blocklist, no DNSSEC,No EDNS Client-Subnet
  • Unsecured IPv6 Secondary: 2620:fe::fe:10 No blocklist, no DNSSEC,No EDNS Client-Subnet
George51
I knew it would be me thick. Thank you, now the ping works and I can get a reply form ipv6.google which proves IPv6 is working on my box, now to progress onto setting it up in my jails too.
I prefer using my pfSense box as a DNS Resolver, so I will be removing googles 8.8.8.8, I was also under the impression that if you had a dual stack, an IPv4 address would work for both - I don't know why or were I got this assumption from. And after you first reply, when I tried the ping6 I only had the 2 original IPv4 DNS servers in.
EDIT: Quick further question: why does the widget for the Primary NIC on the dashboard only display the IPv4 address? Is that normal?
scrappy
I don't know if it's normal or not, but my system doesn't show an IPv6 address either.
I have a similar setup with pfSense and would agree that using Unbound as a resolver is your best option.
