iocage startup script
dknm
I'm trying to setup a startup script to run two lines I currently do manually inside the jail
source ~/py3-venv-pgadmin/bin/activate.csh python3 ~/py3-venv-pgadmin/lib/python3.6/site-packages/pgadmin4/pgAdmin4.py &
I looked at a few resources, namely
https://www.freebsd.org/doc/en_US.ISO8859-1/articles/rc-scripting/rcng-daemon-adv.html
https://forums.freenas.org/index.php?threads/run-command-at-iocage-jail-startup.61819/
And saw 2 formatting styles, tried both - looking like so:
attempt #1
#!/bin/sh
. /etc/rc.subr
name="pgadmin4-daemon"
rcvar="${name}_enable"
load_rc_config ${name}
pidfile="/var/run/pgadmin4-daemon.pid"
command="source ~/py3-venv-pgadmin/bin/activate.csh"
command_args="python3 ~/py3-venv-pgadmin/lib/python3.6/site-packages/pgadmin4/pgAdmin4.py &"
run_rc_command "$1"
#attempt 2
#!/bin/sh
. /etc/rc.subr
start_cmd="${name}_start"
stop_cmd=":"
load_rc_config $name
pgadmin4-daemon_start()
run_rc_command "$1"
And then:
echo 'pgadmin4-daemon_enable="YES"' >> /etc/rc.conf
chmod +x /etc/rc.d/pgadmin4-daemon
Either way, it errors with
service pgadmin4-daemon start
/etc/rc.conf: pgadmin4-daemon_enable=YES: not found
/etc/rc.d/pgadmin4-daemon: WARNING: $pgadmin4-daemon_enable is not set properly - see rc.conf(5).
Cannot 'start' pgadmin4-daemon. Set pgadmin4-daemon_enable to YES in /etc/rc.conf or use 'onestart' instead of 'start'.
Is the syntax I'm getting wrong or something else entirely?
nojohnny101
You have to do as it says and enable pgadmin4 to Yes...similiar to this:
iocage exec tautulli sysrc "tautulli_enable=YES" (for my iocage jail that runs tautulli)
I also had to execute these two statements to get my tautulli jail working:
iocage exec tautulli cp /usr/local/share/Tautulli/init-scripts/init.freenas /usr/local/etc/rc.d/tautulli
iocage exec tautulli chmod u+x /usr/local/etc/rc.d/tautulli
credit goes to this tutorial: https://forums.freenas.org/index.ph...darr-lidarr-jackett-transmission-organizr.58/
Hope this helps.
dknm
Thank you for the resource. I did some digging and found the script the plugin relies on, with the intent of then adapting it.
Also had a look in this thread and my understanding is you don't need to create pid / status / stop variables explicitly.
My script (usr/local/etc/rc.d/pgadmin) then became
#!/bin/sh
. /etc/rc.subr
name="pgadmin"
rcvar=${name}_enable
: ${pgadmin_enable:="NO"}
: ${pgadmin_user:="root"}
: ${pgadmin_dir:="/root/py3-venv-pgadmin/lib/python3.6/site-packages/pgadmin4/"}
. /root/py3-venv-pgadmin/bin/activate
python3 /root/py3-venv-pgadmin/lib/python3.6/site-packages/pgadmin4/pgAdmin4.py &
With this I can run service pgadmin start and it works (I can't do service status or stop though, either will attempt to start a new instance).
It won't however run on startup. (Made it executable and added sysrc pgadmin_enable="YES" ).
Running either lines with command= in front returns permission denied. Probably has something to do with this changing the shell agent from root -> python
root@postgresql:~ # service pgadmin start
/usr/local/etc/rc.d/pgadmin: /root/py3-venv-pgadmin/bin/activate: Permission denied
/usr/local/etc/rc.d/pgadmin: python3: not found
/usr/local/etc/rc.d/pgadmin: WARNING: run_rc_command: cannot run
So, I'm a bit closer but don't know how to go further. Could I get a sense check / feedback please?
isparks6
Hi, did you have any luck figuring it out? I'm running into a similar problem, trying to do the same thing. I want to run pgAdmin in the background as a daemon when my jail starts. Here's my script:
#!/bin/sh
# PROVIDE: pgAdminActivate
. /etc/rc.subr
. /root/pgadmin4/bin/activate
name="pgAdminActivate"
rcvar=`set_rcvar`
stop_cmd=":"
load rc_config $name
pgAdminActivate_start()
    python /root/pgadmin4/lib/python2.7/site-packages/pgadmin4/pgAdmin4.py
run_rc_command "$1"
I can force it to run using onestart, but whenever I try to simply start the script I get the following error:
./pgAdminActivate: load: not found
./pgAdminActivate: WARNING: $pgAdminActivate_enable is not set properly - see rc.conf(5)
Cannot 'start' pgAdminActivate. Set pgAdminActivate_enable to YES in /etc/rc.vonf or use 'onestart' instead of 'start'
I have run the command
sysrc pgAdminActivate_enable=YES
and have confirmed that that line is in /etc/rc.conf. The script has execute permissions. Not sure where to go from here.
isparks6
I figured out the problem on my end. The line load rc_config ${name} should be load_rc_config ${name}. Got caught on the underscore. After fixing that, everything worked as expected!
