tprelog
- Mar 2, 2016
These plugins are for FreeNAS 11.2
Updated plugins for FreeNAS 11.3 can be found here
Given the option of both, I still can't decide which I prefer and I'm certainly not going to decide for others. At first I had two separate scripts, one for installing a standard-jail and also the
Really I made some hybrid plugins for iocage. I say hybrid because by default they will, with two commands, install said application in a plugin type jail. I have also provided a regular
OK, I said I wasn't going to decide for you but I do recommend a standard-jail for Home Assistant because it allows more control. I do not find this need for TasmoAdmin, Mosquitto or AmazonDash.
Amazon Dash
Mosquitto MQTT Broker
TasmoAdmin
Home Assistant
- Run by user/group `hass` with UID/GUID of `8123` matching the default Home Assistant port.
- Includes option to install App-Daemon/HA-Dashboard and(or) Hass-Configurator
- Option to use my pre-configured example files*
- Includes simple menu to execute updates!
Download pkg-list and create a jail using it to install requirements
Optional: mount a dataset inside the jail
Git script and begin install
Answer questions will choose what gets installed
Profit!
Keeping things updated
Please checkout my (almost) complete quick start to installing Home Assistant on FreeNAS 11.2 that also includes an updated manual installation guide for Home Assistant!
*My pre-config examples are optional but without them, you will need to provide your own configs before AppDaemon or Hass-Configurator will start
Install as standard-jails see my GitHub repos Mosquitto and TasmoAdmin and Amazon Dash
Install as plugin (Home Assistant Only) see Home Assistant
If at a later time any plugin should need to become a standard-jail, I have discovered that
post_install.sh
used by the plugin-jail. Then one late night, in an experiment gone horribly awry, the two have somehow mutated into one!Really I made some hybrid plugins for iocage. I say hybrid because by default they will, with two commands, install said application in a plugin type jail. I have also provided a regular
pkg-list.json
that can be used to install the required packages while creating a standard-jail. You can then download (clone) my plugin repo and manually run post_install.sh standard
to finish the install.OK, I said I wasn't going to decide for you but I do recommend a standard-jail for Home Assistant because it allows more control. I do not find this need for TasmoAdmin, Mosquitto or AmazonDash.
Amazon Dash
wget -O /tmp/amazon-dash.json https://raw.githubusercontent.com/tprelog/iocage-amazon-dash/master/amazon-dash.json sudo iocage fetch -P dhcp=on vnet=on bpf=yes -n /tmp/amazon-dash.json --branch 'master'
wget -O /tmp/mosquitto.json https://raw.githubusercontent.com/tprelog/iocage-mosquitto/11.2-RELEASE/mosquitto.json sudo iocage fetch -P dhcp=on vnet=on bpf=yes -n /tmp/mosquitto.json
TasmoAdmin
wget -O /tmp/tasmoadmin.json https://raw.githubusercontent.com/tprelog/iocage-tasmoadmin/11.2-RELEASE/tasmoadmin.json sudo iocage fetch -P dhcp=on vnet=on bpf=yes -n /tmp/tasmoadmin.json
Home Assistant
wget -O /tmp/pkglist.json https://raw.githubusercontent.com/tprelog/iocage-homeassistant/11.2-RELEASE/pkg-list.json sudo iocage create -r 11.2-RELEASE boot=on dhcp=on bpf=yes vnet=on -p /tmp/pkglist.json -n homeassistant
sudo iocage fstab -a homeassistant "/mnt/tank/user/hass /home/hass nullfs rw 0 0"
sudo iocage exec homeassistant git clone -b 11.2-RELEASE https://github.com/tprelog/iocage-homeassistant.git /root/.iocage-homeassistant sudo iocage exec homeassistant bash /root/.iocage-homeassistant/post_install.sh standard
Install Home-Assistant? [Y/n]: Install Hass-Configurator? [Y/n]: App-Daemon & HA-Dashboard? [Y/n]: Use the pre-configured examples? [Y/n]:
Profit!
sudo iocage exec homeassistant bash update 1) Home Assistant 3) Configurator 5) Status 2) App Daemon 4) FreeBSD 6) Exit Enter Number to Upgrade:
iocage export
followed by iocage destroy
and finally iocage import
will do such a trick.
