Paul van der Zwan
- Oct 7, 2016
I just upgraded to 11.1-U4 ( from -U3) and iocage jails still seem to be very tricky.
After boot I need to create bridge0 manually and attach my lagg0 to it to get the bridge up and running.
But trying to start the iocage service I get a Read-only file system error, probably same error scrolls by when booting, and is shown when I run 'iocage list -t':
Starting each jail individually one at a time does seem to work.
Best regards,
Paul
root@freenas:~ # service iocage start
* [I|O|C] starting jails...
File "/usr/local/bin/iocage", line 10, in <module>
sys.exit(cli())
File "/usr/local/lib/python3.6/site-packages/click/core.py", line 722, in __call__
return self.main(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/click/core.py", line 697, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python3.6/site-packages/click/core.py", line 1066, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/local/lib/python3.6/site-packages/click/core.py", line 895, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/local/lib/python3.6/site-packages/click/core.py", line 535, in invoke
return callback(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/iocage/cli/start.py", line 51, in cli
ioc.IOCage(exit_on_error=True, rc=rc, silent=True).start()
File "/usr/local/lib/python3.6/site-packages/iocage/lib/iocage.py", line 1596, in start
self.__jail_order__("start")
File "/usr/local/lib/python3.6/site-packages/iocage/lib/iocage.py", line 172, in __jail_order__
path, exit_on_error=self.exit_on_error).json_load()
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_json.py", line 416, in json_load
conf = self.json_check_config(conf)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_json.py", line 1006, in json_check_config
self.json_write(conf)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_json.py", line 425, in json_write
'w') as out:
File "/usr/local/lib/python3.6/contextlib.py", line 81, in __enter__
return next(self.gen)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_common.py", line 421, in open_atomic
with tempfile(dir=os.path.dirname(os.path.abspath(filepath))) as tmppath:
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_common.py", line 384, in tempfile
tf = tmp.NamedTemporaryFile(delete=False, suffix=suffix, dir=dir)
File "/usr/local/lib/python3.6/tempfile.py", line 549, in NamedTemporaryFile
(fd, name) = _mkstemp_inner(dir, prefix, suffix, flags, output_type)
File "/usr/local/lib/python3.6/tempfile.py", line 260, in _mkstemp_inner
fd = _os.open(file, flags, 0o600)
OSError: [Errno 30] Read-only file system: '/mnt/iocage/templates/template-20180224/tmp40ucr6bh'
Best regards,
Paul
